All batteries replaced and software updated but still losing 10% every 2 days when van is not in use
Last drive mine last Wednesday. Just checked this morning and mine is at 80% - 47.5 hours remaining.
Does the display go down in 10% increments?
4 days and a half not too long considering you had no consumption...same mine; i will take it to dealer today for a seventh time; on summer fridge at level 1 and no other consumption except some water pump lasted 2 days and a half from 100% to 20% ( does not charge while driving so always thinking of hooking up somewhere)
So from Friday / Saturday at 100% to 10% today (leisure batteries) with nothing switched on, sounds like another trip to van hospital is needed maybe with some screenshot evidence, it shouldn’t drain like that.
P.S. When I’ve finished my leisure battery experiment, I’ll take my Cali out of camping mode, switch everything off and monitor the battery drainage with it sitting on my drive. I also have the hybrid on a 25 plate.
So mine was doing that I can now confirm after new batterys and recall, its now holding with only minimum drain
Update
After having it back for over a week. I can confirm its now holding the charge with only minimal drain, for ref they replaced all 3 batterys and pushed the update again, they told me the first time they tried update they dont think it worked
Yes my T5 used to slowly drain my leisures but since adding a solar panel on the roof, bingo, always topped up and ready to go! I guess T7's should have had solars fitted as standard as they aren't that expensive. Does not address the problem but prevents destroying your batts from very low voltage :)
