It turned out that the fuze had blown on the leisure battery…!!! Changed that and the EAC works like a dream now … just tried it at 400w … not sure how much one can push the alternator though ?That’s the key, to set the voltage at 13v. I think the EAC does drain the leisure battery quicker than it is charged though. Although that’s only anecdotal.
I assume you can’t just put a long reach socket on it and undo?
I think it’s actually welded to the chassis. What looked like the head of a bolt has 8 sides. In the end I have cut it lower and it’s still usable.I assume you can’t just put a long reach socket on it and undo?
I've had the AC installed for about 9 months, and I'm constantly observing the behaviour of all related devices. I have my AC set to 13V, so it should never drain the leisure battery when the car isn't running.not sure how much one can push the alternator though ?
Hi all ! I’m new here but would really appreciate some advice.This is how I installed it as a test today to the rear hose battery in a Cali Ocean T6.1 2023. You how know this, does it look ok? Everything seems to work fine, charges with 800W at 13.5 V (after update of EF and EAC) and reverse charges as well. I guess it will only charge the rear AGM battery? I wonder if Calis battery management system will get confused?
Yes, and the smalll electronic thing on the -pole connected with a cable to the +pole as well had the marking in the last picture, just as information.
If it is the Passenger seat, then it is likely to be the Seat Mat used to sense if the passenger seat is occupied. Used for the Airbag System and the Seat Belt Warning.
I have assumed, maybe incorrectly, that the charger needs needs to connect to the starter battery to draw from alternator, however if the split charge relay provides this, then that’s where I’ll connect, one of the functions of the EcoFlow Delta 2 battery is it can provide a boost charge to the starter battery (if flat) when required if connected, I’ll need to investigate if this feature is still applicable if connected via the relay under the seat, certainly make life a lot easie
Mine is connected to the ambient LED lights mounted in the lower plastic trim panels on the rear of the front seats, they appear to be missing on your panel. Lights come on when the door is opened.
Hi, I think you see the same issue I had last year (post 36);I've had the AC installed for about 9 months, and I'm constantly observing the behaviour of all related devices. I have my AC set to 13V, so it should never drain the leisure battery when the car isn't running.
Here's what I've gathered:
When the car is running, I find that the alternator's voltage varies between 12.6 at the low end up to 14.7 at the high end, and where it is on that spectrum depends on how depleted the leisure battery is. If the leisure is low (below 80%), the van sends higher alternator voltage… ~14.4V. The AC just uses excess voltage at this time to charge itself, and I don't believe the alternator is working any harder than it normally would.
However, if your leisure battery is >= 80%, the alternator backs off to 13V or lower. If your Delta needs more power at this time, there is the wonderfully helpful Max Charge button in the upper display of the van (on a T6.1), which will set the alternator to max capacity and send out 14.4V, thus charging your Delta and topping up your leisure. If you find that you have to do this frequently, I think your alternator is indeed getting an extra workout, but without using that, I would not expect so.
However, I will add, that regardless of the AC & Delta, if your van has a steady draw on its leisure battery (mine does due to 5G/WiFi hotspot, Raspberry Pi and more…), and you do a bit of driving around town (it's my daily driver), then nearly every time you get in your van, it will have the alternator running at max, initially, to bring the leisure back up to 80%. But, this is not a new problem that the AC/Delta adds. But, if your leisure has no load and doesn't ever drain much, but your Delta does, your van won't know this (it only assess the state of the leisure), and its alternator will only run at a low voltage, not high enough to charge the Delta (w/o either reducing the AC voltage threshold setting or using the Max Charge button).
I never had issue getting the full 800W when I wanted it. If the alternator wasn't already pumping out high voltage to charge a lowered Leisure Battery, I just turned on Max Charge and got the full 800W… BUT… you generally don't want to charge the Delta at a rate higher than 500W if you want the battery to live as long as possible.Hi, I think you see the same issue I had last year (post 36);
Routing the Cable to install a EcoFlow 800w Alternator Charger
Sorry for the confusion here, I switched off at fuse box at the rear of the van inside the cabinet (Cali Ocean) only, I'm pretty sure that toggle circuit breaker in the rear cabinet only cuts power from the EHU supply. The leisure batteries will still be powering the electronics.vwcaliforniaclub.com
Im reconsidering the EAC, but hesitating because without the 800w charging Im not sure it will fit my needs (off grid, no solar).
Have you managed to overcome the EAC modulating [down] its current draw clashing with the alternator 'modulating' its output current based on leisure battery needs?
What do you mean by this?with the 12v charge cable running to the right hand accessory socket
Any chance you wouldn't mind posting some images ofvyou setup please as I'm considering exactly what you have completed. It would be very much appreciated.Okay, it's done! Super happy. Dont know what I was fussing about.
I drilled a discrete hole in the rear battery compartment door. Grometed it and shortened the EAC input cable. EAC and Delta 2 sit nice and snug in the rear left corner of the boot, with the 12v charge cable running to the right hand accessory socket, a 1m extension lead routes the 240v output through the tunnel beside the bench seat to the saloon and the 240v charge lead is plugged in and stored wound up inside the tunnel for 'hooked up' charging.
Simples.
It all just works! yay.
Sure,.. when I'm next tinkering I'll put some together.Any chance you wouldn't mind posting some images ofvyou setup please as I'm considering exactly what you have completed. It would be very much appreciated.
I was plugging the ecoflow into the 12v accessory socket too, but now realised that you can modulate the charge current quite accurately down to 10A (via the EAC) using the app, so just 12v charge via the EAC nowI never had issue getting the full 800W when I wanted it. If the alternator wasn't already pumping out high voltage to charge a lowered Leisure Battery, I just turned on Max Charge and got the full 800W… BUT… you generally don't want to charge the Delta at a rate higher than 500W if you want the battery to live as long as possible.
I've since installed a Victron SmartSolar, also connected to the leisure battery, which is kind of neat because as that is charging the Leisure via the solar, it raises up the voltage, which of course, makes the EAC kick in as well, and both batteries get charged!
