Over filling with Adblue
Nottledim
Nottledim
Shropshire
T6 Ocean 204
I think I have added too much adblue to the adblue tank and the dashboard still says I need to add adblue. Do I just wait till the level drops or have I broken the level monitor?
Why do you think you have added too much?
The dash said max fill 3.5 litres I added 5 there was no overflow or puddle so I’m sure it all went in
I don't think you have a problem - I always fill mine up until the valve on the dispenser stops the flow - never had a problem.
I don't think it resets immediately but after a few miles driving. I cannot confirm as I don't have a T6.
Also, on some VW vehicles it is suggested Turning just the Ignition On for 1 minute and then Off for 1 minute then start normally.
If it doesn't clear then its the Dealer I'm afraid.
I’m just concerned that I don’t know the level in the tank if the warning display always says adblue range 1000 miles even when it’s full or over full.
I did the ignition off and on and I have driven about 60 miles so far so yes it’s off to the dealers.
I quite like Hereford.
There are reports of them failing on other Adblue vehicles but not many at all on the T6.
I’ve not overfilled mine (yet) but I’d imagine it’s more likely to just make your shoes wet rather than damage anything.
If the MFD didn’t reset after a drive & a couple of key on / off cycles then I’d take it to a Dealer too.
Separating the issues...
Like the water tank and the fuel tank, I don't understand how you could over fill the ad-blue tank without it coming out of the filler neck? I appreciate with engine oil you could put too much in but this is because of all the moving thingyamyjigs, changing temperatures and pressures when running. But the afore mentioned are just tanks... or at least the water and fuel tanks are anyway. Maybe there is something I'm missing about the adblue?
So dare I ask if you put it in the right filler? sorry if that sounds basic, just checking.
Getting it wrong would also account for the level monitor not moving.
If you have put it in the right filler neck then it sounds like you have a fault with the monitoring system. No idea how that works though.
Valve on the dispenser? I guess you mean at a forecourt. I fill mine up from a 20 litre container with a funnel and judge how much I put in. Dash display updates accordingly. A lot cheaper too.
http://www.distribution365.co.uk/pr...fu0ccgIrPGpTDVIbJkfnZ8fK8zKhPOgphEaAkjl8P8HAQ
No I don’t mean a forecourt. I bought a smaller bottle from Halfords that came with a valve based dispenser. I then fill that smaller bottle up from larger 20L containers of Adblue as per your suggestion. That way I get a controlled fill that auto shuts off when it’s full avoiding spillages. Hope that helps!
Sometimes its a good idea to read the manual ;-)
In this case (from memory) it states that, after filling AdBlue, you turn the key one step. Wait for the AdBlue level indicator to sort. Then start the engine. Or turn of ignition again. I don't have the manual her, so I do not know about overfilling (only that it is a problem if you overfill engine oil - but that is a whole different story).
Mine is listed in gallons not litres when I get to about 400 miles range left the dash tells me to + adblue min 1.25 gallons and max 2.25 gallons so fill with 10litre bottle no pumps near home. I always thought there is an issue if you over fill as why would there be a maximum on the dash.
After filling with adblue you must turn on the ignition and wait a minimum of 30 seconds before starting the engine.
Also there is a minimum fill of 7 litres for it to register.
Yes, helps thanks. I have to confess that when the dash display says fill up with a min and a max numbers of litres I put in approx the mid point by guess work to avoid spillages. Been OK so far! Famous last words!!
Just filled up today 14l cost free. Chap said he take payment next time. For the first time it's showing as 6000 miles. It's always shown a max of 4500 miles before.
6000 miles? Must be code for careful driver!!
Filling up at the forecourt is much cheaper.....on average less than 60ppl
I use a truck dealer, Thompson Commercials, a Renault truck dealer. May be worth looking for something similar in you area?
R
RedWhiteMonkey
R
john eagle
13K
Amarillo
Amarillo
Meoncoast
19K
Gilesplus
Gilesplus
