Ghostbuster
Yes it has sagged in cooler temperatures but never to the point where it has re tensioned. I always thought this was a myth until this weekend.I'm afraid VW will tell this is within limits of normal behavior but you can try. If it is only in very hot weather then probably the behavior described will not happen while it is inside the VW garage and they will tell they are no able to reproduce the error.
You never had this sagging before in less hot weather ?
I forget to mention the lights in the roof failed on both occasions. I read this has happened to others.
I raised the roof this lunch time. It’s now 7pm and it’s just on its decent now albeit only slightly and the temperature is a bit cooler this evening.
