ALTYGEZZER555
Fridge not working in my 2022 T6.1 California Ocean. Was working perfectly until I brought my vehicle out of my local dealership after having other unrelated investigative assessment (unrelated to the Control Panel or Infortainement Panel that is).
Control Panel shows red warning triangle against the fridge so it is inoperative. No other feature is affected. Pulled fuses 5to8 to try to re-boot the control Panel but no luck there. Read somewhere in forums to remove/reinsert a red 10a fuse under the passenger seat but again no luck.
Tried to get the dealership to diagnose but they want 3 weeks notice just to have a look and we have a holiday trip in our van booked commencing June 27th which we would be loathed to cancel (and expensive!).
I also read somewhere that disconnecting the negative terminal on the engine battery would re-boot the Control Panel but don't know if this is accurate so haven't tried this.
Has anyone had this same problem? Can anyone help me to resolve this? I would be so so grateful. Alternatively if anyone could recommend an engineer/specialist in the Greater Manchester area (or even a bit further afield) agian I would be very appreciative.
