FRIDGE RED WARNING TRIANGLE
ALTYGEZZER555
Altrincham
T6.1 Ocean 150
Fridge not working in my 2022 T6.1 California Ocean. Was working perfectly until I brought my vehicle out of my local dealership after having other unrelated investigative assessment (unrelated to the Control Panel or Infortainement Panel that is).
Control Panel shows red warning triangle against the fridge so it is inoperative. No other feature is affected. Pulled fuses 5to8 to try to re-boot the control Panel but no luck there. Read somewhere in forums to remove/reinsert a red 10a fuse under the passenger seat but again no luck.
Tried to get the dealership to diagnose but they want 3 weeks notice just to have a look and we have a holiday trip in our van booked commencing June 27th which we would be loathed to cancel (and expensive!).
I also read somewhere that disconnecting the negative terminal on the engine battery would re-boot the Control Panel but don't know if this is accurate so haven't tried this.
Has anyone had this same problem? Can anyone help me to resolve this? I would be so so grateful. Alternatively if anyone could recommend an engineer/specialist in the Greater Manchester area (or even a bit further afield) agian I would be very appreciative.
leisure batteries charged?
did you check if any of the fuses SC5 to 8 haven't blown ?
Check the cube fuse. - search function will throw up lots of posts
Thanks I will check the cube fuse! I haven't properly sussed how to use the site forum(s). What needs updating?
Search function = spyglass top right - in the banner
Click on it and it will bring up a search box, put in the search string you want - I.e in this instance "cube fuse" and you will be shown posts with the word "cube fuse" in them . You can search on any words.
See below results for "cube fuse"
Thanks for that I will do that in future. Cheers!
Thanks for your response. I followed the link and removed that 5a fuse but the red warning triangle remains in place.
It sounds as if you may have an actual fridge fault, rather than Control Panel.
Mmm after trying the various fuse removals it crossed my mind that that maybe the case. We had used it daily for weeks on a trip to Portugal without any hitch. I will get it to a dealership for checking out. Thanks for your support WelshGas!
jhgf
Jabberwocky
26K
Ta51tac
T
JohnGuppy
2into1
2into1
DavidH
5K
Corradobrit
Corradobrit
