Sorry can't link or edit but it's here:
It’s because it puts it overweight. Same reason you can’t configure a fifth seat with 4M.Add to the diff lock "icing", the cherries of an 80 litre tank (which strangely the configurator didn't offer Joe Public as an option with 4Motion) and adaptive suspension.
| Feature | Notes | California | PV5 |
| Range - Daily Driver (There and back) | Average car journey is 20-40 miles | 200 miles | 80-100 miles |
| Range - Camping Trip (longest ongoing range) | Average holiday journey 80-200 miles | 450 miles | 190-220 miles |
| Height | 1.96m (T6) 2.02m (T6.1) | 1.92m (H1 standard roof with no pop-top) | |
| Weight | 2140kg (full and complete campervan with full tank and driver) | 1900kg (H1 base vehicle with no camping conversion) | |
| Available Payload (how much more it can carry) | 910kg | 710kg (so any camper conversion needs to sit within this and usually can be around 200-400kg) | |
| Living space battery power endurance with 2000w induction hob boiling water (set to a high heat) | 90 minutes (Dedicated leisure batteries) This assumes no use of solar panels or running the engine to top them up. | 20 hours (Vehicle battery itself is used for all power to the living area) It would be 27 hours but the on-board systems ensure 20% battery remains for vehicle driving | |
| Purchase Price | £86,000 (T7 2026) £62,000 (T6.1 2024) £45,000 (T6 2017) (all are 4Motion models) | £30,000 (H1 2026 with 71.2kwh battery) £20,000 (additional Camper conversion cost) £68,000 (Luxury Sussex Campervan Conversion) | |
| Fuel | Diesel (Engine and living space heating) Propane (Hobs) LifePo4/LeadAcid (Leisure Batteries) | 71.2kwh vehicle battery pack (Long range version) | |
| Fuel cost | £160 (full 80 litre tank at around £1.70p/Litre) 450 mile range (60mph) | £24 - Home charging £7 - Home charging off-peak (overnight) £35 - Workplace/public charger £65 - Motorway DC fast charger service station This assume 0%-100% charging whereas usually one charges up from around 10% to 80%, going up to 100% only for long journeys. | |
| Average Service costs (Lifetime) | £20,000 | £10,000-£12,000 | |
| Average Service Cost (Intervals) | £2,500 Oil, oil filter, air filters, cabin filters, coolant, auxilary belt, timing belt, tensioners, aircon re-gas, water pump, hoses | £1000 Battery coolant, water pump, hoses,Cabin Filters, Aircon re-gas | |
| Average Tyre cost | £100 (17") (235/55 R17) | £85 (16" 215/65 R16) |
I was perfectly happy with my Golf GTE PHEV, bought new in 2017, mileage only about 35k and still immaculate. I had assumed it would be as reliable as my T5.1 Cali, bought new in early 2014, mileage now 125k. I had hoped that, with luck, both might last another 5 or 6 years, by which time my wife and I will both be 80 and maybe not driving so much. That's probably a reasonable expectation for the Cali. But earlier this year the GTE suddenly became completely undrivable following failure of the mechatronic unit. The replacement part is very expensive and it needs a highly qualified technician to fit it, because of the high voltage circuitry. It is in a difficult-to-access part of the engine compartment and the work is labour intensive. It's fixed now, but it cost me over £6,200. I expect it would have been even more expensive at a main dealer, bringing into question whether repair or scrap it. I now understand that these mechatronic failures are now a recognised issue in VW Group PHEV engines of this age. Since 2017 VW have replaced the troublesome DQ400e component and it is hoped that this will help. But it is too soon to tell. It remains a much more complex engine than a standard petrol / diesel and there is potentially a lot more to go wrong. "Which" reports that PHEVs have the worst reliability record of all engine types. I had previously been toying with the idea of a PHEV Cali, but no longer!I'm toying with sinking £80k into a PHEV Cali, but obviously have my worries.
In 2019 I sold an 2017 Ocean thinking that residuals were about to tank and I clearly got that spectacularly wrong!
My logic then and somewhat now is that Calis retain values so well because they have such a long serviceable life and they only evolve gradually, giving 30+ years of demand easily. But electric vehicles were on the horizon, even if useable vans were a long way off.
But now the Kia PV5 (and now the 7) is here and the timetable to viability looks different
I'd speculate the next Cali will be electric, or they'll be a fully electric model, not just a PHEV. If that's right, how will diesel, petrol and PHEV Calis look even 15 years down the line, and what will that do for residuals?
The new Cali PHEV suits my current needs very nicely, but I'm aware it's likely never likely to garner the same love that the previous (fully 'T') models did. Might it get squeezed between the loved T4,5,6 and the next fully electric model?
I'd be interested in your thoughts. I don't need any "just get on with your life" advice. I'm doing that, I'm just curious about this thought experiment.
I’m currently planning 2 EV trips with our 250 mile range. Norfolk and the Alps. The French one is looking all very doable and straightforward. Norfolk on the other hand is looking pretty tricky. V few fast chargers in towns and villages.Clearly if you need to get to the South of France for a 10 day holiday, then an electric camper will be further away.
Keep any thoughts coming
This is such a useful perspective. Overnight charging at 3.4p is effectively driving around 300 miles for £5 vs £80 for the same distance using diesel, at the moment.I’m currently planning 2 EV trips with our 250 mile range. Norfolk and the Alps. The French one is looking all very doable and straightforward. Norfolk on the other hand is looking pretty tricky. V few fast chargers in towns and villages.
All French and Spanish campsites we visited this summer were full of EVs.
Octopus has just cut our overnight rate to 3.4pence a kWh. Our large BMW EV does 3.4 miles per kWh. That’s 1 pence per mile. The Cali costs £15 just for us to pullout into ULEZ traffic ! That’s 1,500 miles in the EV!
I can see the logic of PHEVs but I’m glad we skipped one. Complicated engineering.
Looking at zapmap I’d say the charging network in Norfolk is sufficient. What am I missing?I’m currently planning 2 EV trips with our 250 mile range. Norfolk and the Alps. The French one is looking all very doable and straightforward. Norfolk on the other hand is looking pretty tricky. V few fast chargers in towns and villages.
Eh? How? I thought the cheapest rate is 7p/kW overnight (which is still cheap)Octopus has just cut our overnight rate to 3.4pence a kWh.
Good shout. I’ll look at Zapmap. I was using Googlemaps and Chargemap. All fast chargers seemed 15 minutes drive away.Looking at zapmap I’d say the charging network in Norfolk is sufficient. What am I missing?
My Cali is a 174 5 cylinder from 2008. It’s £3 in the EV or well over £100 in the VW!This is such a useful perspective. Overnight charging at 3.4p is effectively driving around 300 miles for £5 vs £80 for the same distance using diesel, at the moment.
That's incredible rates, I've just had a look and what's on offer is a lot higher especially the day rate. Are you on an old deal that's continued at that rate or will yours be increasing soon? CheersOurs was 7p but I looked 2 days ago and they’ve quietly halved it!
Me too, however don't forget you get the whole house at cheap rate for 6 hours whether you charge the car or not. We are on a legacy rate at 7p overnight and 30p during the day. I am very jealous of your 3.49p rate!My favourite fun fact is I don’t have a charger for my 74kWh EV. I charge at home on the drive using the 3 pin plug in the garage!
But that must take ages I hear you cry! Yep about 6 hours 60-80%. But on Octopus Intelligent Go the whole house is 3.49p per kWh. Been doing that for 3 years.
The slower you charge, the better!
Sure. My view, for what it’s worth - the Multivan Cali is a niche product in a niche market ie. It works well for some but not the majority of the target market. It doesn’t appear to have sold well, thus big discounts and previous models holding value well. Hybrid is also a niche market, it excels neither as an ice or Ev. So a double compromise if you like.Ladies and gentlemen, could we get my thread back on track?
I think you have just gifted all here to go right off track with that one!I was a bit behind the developments on trucks. This was well timed by YouTube's algorithm
That was our first EV. One of my favourite ever cars.tempted to pick up a cheap BMW i3 until diesel calms down a bit!
