Adblue not resetting once filled
T
Twojumpers
Sussex
T6 Ocean 204
Hi
I’ve got the problem of the AdBlue warning not going away once filled. I’ve left it a bit to see if it sorts itself out but it doesn’t seem to be going away and it’s down to 650 miles now. I didn’t over fill it and also added a bottle of Wynns.
My usual mechanic has said it’s either a trip to the VW main dealer £££! or get someone round to code it out, which I’m not so sure about.
Any advice is appreciated
It’s a 2016 T6 200hp Ocean and I’m in Brighton FWIW.
Hi
I am reliably Informed VOSA are looking at introducing a check for Adblue during future MOT.
VOSA are acutely aware that many people are circumnavigating factory measure relating the Emissions control and it is becoming routine practice, with no consequences.
Code out / deleting the Add blue system could become the most costly In the long Run.
I.e.
It will be an initial cost to code it out,
then additional cost to code it back, (when / if the new Mot comes in )
then additional cost to replace the whole ad blue system.
Think carefully before committing to Deletion of Emission devices.
Edit: if you reach zero miles on the count down , it can be reset by most garages with a Code reader. So you get another 600 mile count down etc
It would appear there may be anecdotal evidence to suggest early T6 (2016- 2018) adblue systems fail around 60- 70k miles. This may or may not be by design!
Vw arbitrarily replace the whole tank, pump sensors (the whole system) but the components are available individually- currently looking into this and will report back.
Can you advise what mileage the van has done pls ?
Related threads
How to carry out an adaptation drive - force regen and reset or Add blue system without OBD reader: post #41 VW GURU
Except
I am reliably Informed VOSA are looking at introducing a check for Addblue during future MOT.
I.e.
then additional cost yo replace the whole add blue system.
It would appear there may be anecdotal evidence to suggest early T6 (2016- 2018) add blue systems fail around 60- 70k miles. This may or may not be by design!
It’s on 66k.
Do you know if it’s something an independent vw specialist can do?
Purely info - I do not know this company and I am not recommending them. There is some useful info in the guide , particularly fault codes etc
P218F00 Reductant No Flow Detected
And
P046C00 EGR Sensor “A” Circuit Range/Performance
Read the
It’s on 66k.
i don't see why they wouldn't be able to resolve it, you have two issues that have codes, that's a good starting point to make contact with. .
Hi,
I had this problem with AdBlue and other related faults with EGR/DPF at approx. 50k miles and 6yrs old - many new parts later! ..seems inevitable with a Euro 6 engine :(
For the AdBlue not registering, after a visit to two independants who checked injectors, scanned codes but could not determine the root cause. I took it to VW and ended up replacing the entire AdBlue tank and sensors, cost approx £1700 with a two year warranty.
If this is the likely outcome, worth getting quotes from independants to compare to VW.
Goodluck!
From my VW Mastertech pal, the key is when filling leave the ignition on and it will register straight away, it gets confused when the sensor isn't active and then you fill. Has always worked for me.
Thanks, I’ll make some calls
Interesting tip and hopefully solves it for others.
For me, and maybe 'twojumpers' this cannot work because AdBlue system has already failed. The tank has been refilled but the sensor has not detected any fluid and is counting down from 650 miles requesting a top-up. I tried everything through forums and mechanics to reset the system but zero success. Once the 650 miles ran down the van enters limp mode. This happened twice in succession and had no option but to fix the problem. Some mentioned the AdBlue crystalising and damaging the sensors overtime (a crazy situation).
With my T7 (also a Euro 6 diesel engine) I'm now adding Wynn's anti-crystallisation with every AdBlue top-up in hope of preventing this with my new van... fingers crossed.
Yes, I put the Wynnes in also. Can I ask how many miles you do roughly in a year?
Van Tech in Uckfield are well regarded and fairly local VW accredited specialists.
They may be worth a discussion.
Hope you get a positive outcome.
Interesting you added the Wynn's solution and the system still failed. Is this a new thing or something recently started?
I'm probably 10k miles a year now. Initially my T6 was only a weekend adventure van so 5k per year. I've switched things up now and use my T7 as a daily and camper which is brilliant with all the tech and comfort. Allows for some extra fun in different weekend cars.
No, system hasn't failed for me, always fill with ignition on and with a bottle of Wynnes. No issues ever.
I’ve a Kombi 150 that had adblue issues earlier this year. Luckily under warranty, it turned out to be the NOX sensor. Cost around £1800 but took a few weeks for them to actually find the fault as vw wanted a software update going 1st then the vehicle running. Tbh I think this was a cheap fix for vw had it worked, it didn’t
Based on this thread I have just bought 2litres of Wynns... 20cc to 10litres of Adblu so it will last a fair old while! My van does sit for a time between runs.
Curiously it says "Do not add directly to the vehicle tank" on the label. Must be premix only but I'm not sure why...
Possibly because you know the exact quantity of Adblue in a new container whereas the quantity in the vehicle tank would just be a guesstimate.
How much did you add on refill? I had an issue once when I tried to refill with a small bottle, it didn’t register. So I had to by another small one to cautiously top it up.
Is it worth you buying an OBD11 and clearing the faults? They are a real handy thing to have anyway for the odd time a VW electrics have a wobble
I.e.
Sadly I was in the same boat this Summer on a trip to Europe. In the end I had to get the tank replaced.
As it was touch and go whether I had range to get home left it in Germany and flew back for a week and a half (luckily I was due back in Germany a week later anyway and the garage was owned by a friend so got it done more quickly than a main dealer here).
My T6 Ocean was low mileage and it sits about a bit … I’m if the Adblue is allowed to be at a “low” level for a long time the bigger air gap allows crystallisation - so from now on I’m not leaving so long to fill up and will add Wynns regularly. I’ll also try and find a Adblue pump as I’m told the Adblue in there is fresher.
I’d love to hear of any fixes avoiding a full tank replacement as even with a “friendly” repair it wasn’t cheap.
