T6.1 Ocean 2021 model lithium install (trying anyway)
Hey sounds sensible - however without being a debbie downer i dont want to give advice i cannot backup. I think if you have mocked up and measured then as long as enough ventilation and secured the battery either to seat frame or base (maybe use Threaded inserts / Rivnuts so not to invite rust going all the way through), make sure correct cable sizing for loads etc then you will be fine.
Do you know what is below the passager's seat? Can i do a tapped hole to fix the battery ?
Does anyone know what is max current we can draw to charge the batteries on a t6 california coast 2018? The Orion can go up to 50A.
Thank you !
Thank you !
I would remove the underbody protection before drilling as the Webasto Engine Coolant heater is positioned on that side of the vehicle with fuel pump, lines and wiring harness.
