Another Fridge issue T5.1 California 2011
chez786
chez786
bingley
Hi
Falling at the mercy of those of you who may know a bit more about our Vw Cali . We have done the following issues
- fridge not working on hook up or whilst driving
- leisure batteries not charging when driving
- roof not wanting to work ( although this may be a separate issue )
Fuses under seat replaced if not working
Split relay has also been replaced (this afternoon)
Fridge working when powered independently
Batteries are healthy
Fault codes 3101 and 3001
Please help us avoid a costly and frustrating trip to a vw dealership .
Thanks in anticipation of your ideas . Photos would be great .
Cheryl
Hi
Cheryl
So is the Spli Charge relay now working?
Have you cleared the Diagnostic Codes on the Control Panel?
Check Control Panel Diagnostics.
Control Panel Off and wait 30 secs
Control Panel On
Press and Hold R lower button and then press Control Knob for 5 secs.
New Hidden Menu . Scroll to VW Diagnostics.
If there are any codes shown, take note and then Reset/Clear, using R lower button.
Return to Main Menu.
Switch Off Control Panel using L lower button. Wait 30 secs and Switch On.
Try Roof/Heater or Fridge
Control Panel On
Firstly many thanks for replying on a Sunday afternoon .
Fault code that is left is 3101 . When turning on the fridge I can hear something clicking at the back of the van . Unfortunately fridge still not working
Fault codes and VWs cryptic meaning.
Error Codes from Control Panel.
1 = 1 = Pop-up roof
2 = 2 = Plumbing Heating
3 = 3 = Cool box Cooler
4 = 4 = Sewage wastewater
5 = 5 = Fresh water
6 = 6 = Outside temperature
7 = 7 = Battery
Error Code Defect Fault
1010 1010 Short-circuit to (earth) roof
1001 1001 Fuse / short circuit to (plus+) roof
1100 1100 Short-circuit output Roof "on"
1101 1101 Fuse roof "to"
1110 1110 Short-circuit output Roof "to"
1111 1111 Fuse starting Roof "to"
2100 2100 Short-circuit output heating on / off
2101 2101 Fuse output heating on / off
2001 2001 Interrupt input heating 30
3100 3100 Short-circuit output coolbox
3101 3101 Fuse interrupt output coolbox
3001 3001-J698-cooler input error "Active"
3010 3010 Short-circuit input icebox "actual temperature"
3011 3011 Interrupt or fuse input icebox "actual temperature"
4000 4000 Short-circuit to ground water level sensor
4001 4001 Fuse circuit to plus water level sensor failure
5000 5000 Short-circuit to ground water level sensor
5001 5001 Short circuit to plus water level sensor failure
6000 6000 Short-circuit to ground temperature sensor or for outdoor temperature
6001 6001 Fuse / short circuit to plus two temperature sensors for outside temperature
7001 7001 interrupt input interrupt input D +
Trouble shooting guide.
Again thanks for the weekend advice . We have rightly or wrongly determine that there is no power to the following part of our diagram . My other half expected to to be live .
Another update - fault finding has brought us here
Does anyone know where this fuse is located
There is a Fuse Layout pdf in the Resources Section of the Forum.
That fuse is located in Fuse Box SA, which is in the engine compartment below the engine battery.
