Fridge issues - California SE 2011
chez786
chez786
bingley
Hi all we have ongoing fridge issues with our 2011 se . Currently not charging or working when driving . This weekend we had the added delight of it not working on hook up . With a multimeter and this forum in hand we set too - hoping to diagnose the problem . Heads up to all of you who have posted solutions you have helped us problem solve this afternoon . We think it may be a square fuse like item ( in the photos ) or the Danfoss component i( again in the photos ) The Danfoss component looks just over £100 . So we don’t want to waste the money if we haven’t checked everything else . We have
checked the fuses under the passenger seat and had a check of what we can in the compartment in the kitchen .
Is there anything else we may of missed that we can check . Any relays ? Fuses / switches for the batteries we may of missed .
Thanks in advance
Cheryl
That’s a relay in your hand. Your post is confusing. The fridge doesn’t charge. Do you mean the batteries are not charging or the fridge isn’t fridging?
Apologies fridge isn’t staying on - not at any time. Neither on hook up or not .
I’m my experience, it’s the Danfos box.
I would check the charge of the leisure battery. From memory, if it drops below 11.5v the fridge won’t operate. The engine doesn’t give it a full charge but an overnight plug-in at home tops it up. It could be as simple as that.
