DonGraham
Hi, I'm just wondering if anyone has come up with a cunning plan to make emptying the grey water tank easier. I have had a small stick on arrow cut out of vinyl to show the position of the valve in relation to the drain, that made things much easier, but then I still have to get down on my knee to reach under the van to turn the valve. Usually with the ground soaking wet from previous users.
I've wondered if it is possible to bring the valve closer to the outside of the van, I also made an extension tube with a cut out to go over the valve, but you've still to locate the valve.
The obvious solution is to change to an electric valve, but I have been put off due their reliability in such a hostile environment under there.
Has anyone come up with a better idea?
