Sebe
Hi everyone,
I recently purchased a 2023 Grand California 600. I’m the second owner. Before buying it, I inspected the camper and didn’t notice anything suspicious. I even spent a night in it, using both the water system and the heating, and everything seemed to work fine.
However, on our first trip with the family after the purchase, I noticed that whenever we used the water system, some water leaked at the rear, around the rubber seal of the left-hand rear door.
I checked underneath the furniture inside the camper but couldn’t find any cracked hoses or water on the floor. That said, the space inside the cabinet where the fresh water tank is located is quite cramped, with everything packed closely together, so it’s difficult to get a good look at the floor underneath.
Has anyone else experienced similar leaks? Or could you give me some tips on what and where I should check? I’ve attached a few photos and marked the area where I noticed the water coming out.
A second question about the water system:
Whenever I return home from a trip, I usually empty the fresh water tank.
Before leaving for our trip last weekend, I filled it with fresh water. However, when we arrived at our destination and tried to use the water for the first time, nothing came out of the tap. I noticed that the valve underneath the passenger bench seat was open, and water was draining underneath the camper from somewhere around the middle of the vehicle. It was dark outside, so I couldn’t see whether there was a hose in that area or exactly where the water was coming from.
I closed the valve, but water continued to drain for a few more minutes before stopping. After that, the tap started working.
What I don’t understand is whether this valve opens automatically every time the fresh water tank is deliberately emptied. Or if I turn off the power to the camper through the general electrical switch, does this valve open at that moment because no power and consider it an "emergency situation"?
I’ve read online that this is a frost protection valve. If the interior temperature drops below 5°C, it opens automatically and allows the water to drain from the system to prevent frost damage.
But if it’s not cold, under what other circumstances can this valve open and drain the water?
Also, what is the small round button next to the valve for?
Finally, a question about winter storage:
We probably won’t be using the camper during the winter, so I’m wondering what needs to be done to prepare it for storage.
Apart from emptying the fresh and waste water tanks, is there anything else I should do? I was thinking of parking the camper on a slope to help ensure that all the water drains out of the pipes.
I’m planning to store it in a large garage-style tent designed for motorhomes and connect it to an external campsite-style power outlet.
If I leave it plugged into the mains, will both the starter battery and the leisure battery stay charged? Or does the engine battery have to be charged separately?
Any other tips or recommendations for preparing the Grand California for winter storage would be greatly appreciated.
Thanks in advance for your help!
