Out of interest, when the GPS unit failed, were you able to see the van's location in the VW app. I can see it nowI had this a few months back. VW replaced the GPS unit under (All-In) warranty. That was nothing to do with software. Just a thought……….
No, but that’s simply because I don’t use the appOut of interest, when the GPS unit failed, were you able to see the van's location in the VW app. I can see it now
Well………. They said it was around £800Hopefully, if it is the GPS unit and they already have it in the workshop, I might not be charged two arms and a leg.
Some light reading.Spoke with a VW dealer and they reckon there was a software update to disable the 3g/4g for the SOS module. The van's record shows that the software didn't complete properly, so the sensors are complaining.
Booked in for a diagnostic. Out of warranty and no charge as it's VW's buggy software.
Curious to hear if others get this issue as it was caused by an inital OTA update a few days ago,
Very useful! ThanksSome light reading.
T6.1 SOS fault.
Hi I have looked in the forum on threads with SOS faults, and also I have used Carista to look at any fault codes and have the attached the two it found. Looking at them it looks like the battery backup has failed and I assume that this is the issue with the SOS module. Assuming that this is...www.t6forum.com
Gotta love VW and their dealers!Also had this issue early last year on a 2020 ocean. Had issues with the infotainment system since new and vw insisted there were no software updates. Took it in, they fitted a new antenna and installed 3 software updates that had suddenly appeared. Took the best part of 2 days to download at a cost of £450. Still not right, booked in for diagnostics and found one of the downloads hadn't completed. All sorted eventually and we got recompense off vw.
I had to book mine in for a date when they have a loaner car as I need to leave it all day. Looks like this is an expensive software bug for VW.
Can you let us know how you get on as my appointment isn't for a month.Yeah I was offered a loaner too which I found surprising for a software update!
Yes, you mean the Coasts/Transporters need to attend VW for the update rather than the vehicle updating itself. That seems likely.I wonder if this is specific to Coasts / Transporters without the upgraded media systems.
Subsequently I have also needed to log in again with email and password on the central screen so that the van reconnects to We Connect and/or My Volkswagen and then synchronises. I also had to reset the privacy settings to be sure I got further updates in the future.I got this today, (MY23 Ocean) which took 15 minutes to download part driving then part parked with ignition on:
I failed to photo the initial detailed explanatory screen.
Then I got this:
Which took another 10+ minutes install.
Then system update cleared.
Is this perhaps a cure to the same issue as the original post?
.An update. Took van to the dealer.
They told me the sos battery needs replacing and only when the battery has been replaced can they do the software update.
I’m out of warranty but they have said they will not charge me. Something about a factory claim….
Batteries are on back order so still greeted by an orange BEEP when I start the engine.
Same for ours Ocean 150. 22MY. SOS error after software update that’s apparently crashed the whole infotainment system and SOS which is all linked. Dealer has an SOS module on back order which has to be swapped before update and then hopefully will get Sat Nav and rain system working again! Diagnosed early January and still waiting!An update. Took van to the dealer.
