Battery completely flat
F
FrizzyJenko
Essex
T7 ocean
Hey all, so my new California has been parked up on the drive; it’s been a month since it was last driven. I opened the door a couple of times this afternoon to put a couple of things away (I didn’t turn anything on). A few hours later we are unable to open the doors at all. We had to use the manual key to get in and it turns out that both the main battery and second battery are completely flat. The second battery won’t charge when I plug into the house.
I’m going to call VW in the morning but I wondered if anyone has any suggestions as to why this has happened?
Which engine do you have?
Have you had the recommended VW update installed?
This is a well documented issue I’m afraid.
Search on this forum, there’s already long threads on this with details of updates etc.
Well, it’s been recovered to the local VW van centre this morning so hopefully they can give us some answers ‍♀️
just wondering if you had any luck with the issue? I had exactly the same problem, not driven the car for just over a week. And it was flat out this morining. Its a 2.0 tdi t7 from 2025. I pluged into mains and it charged the leasure battery fine, now the power is back in the back of the car, however it does not charge the engine battery at all, on the camper back pannel it shows as red with no indicators at all. And the front panel is just off, central locking also doesnt work. Its weird as everything was all fine since i got it 6 months ago.
unsure on t7 but on t5.1 it will only start charging the starter battery after the leisure batteries are completely full. Does it say anything in the owners manual about it?
It sounds like we are having the exact same issue. VW have now had it for a week. So far they have said the batteries (which they have now charged) are fine. They have recommended that the vehicle is never left for more than two weeks without starting. If you do have to leave it for that length of time, then they say to use a trickle charger or to leave the van with the engine running for 35-40 minutes. Neither option is ideal. We are currently questioning why this was not explained to us when we bought the vehicle as we did specify we were only planning to use it during the summer months and also whether this van will be able to operate when we want to use it off grid for one or two nights. I was hoping they would just do an update and all would be solved! Good luck with your van.
