180 Biturbo Engine
G
gatvol
With older vehicles like this, in bygone days you might buy a used "good" engine and swap the original out.
However, who would trust a used biturbo engine given it's reputation ?
Can you buy a used good single turbo engine- but strap [new] biturbo ancillaries/ turbos/ egr to it? Or does the biturbo have a different block/ pistons/ head/ inlet ??
It should be perfectly possible to transplant at 140 engine in place of 180
180 is not the same ancillary parts and cannot be bodged up to make a 150 fit a 180 spec , lower engine (block etc is the same) upper engine (twin turbos, pipe work etc etc are not )
Almost deffo a different cam and ECU. Nice try tho :cheers
