Engine Management System icon
BeeBee
Glasgow
Hi, looking for some advice on EMS icon appearing on dash.
Last two journeys ( approx 20 miles each ) icon came on constant amber .
Decided better book into dealer to check out /diagnose and decide not to drive until diagnosed.
This morning needed to use the van on the same journey, icon still showing , however on the return journey, ignition on …. no icon !
Should I cancel the dealership booking or just check it in anyway. I’ve got another two weeks till appt. so I could run the van a few times see if it reappears.
All views appreciated.
Buy a Carista. Look up the codes.
Amber generally means ok to drive but get checked out. I drove on an amber for a year once I know what it was.
I should have said van is 2019 Calli ocean 150 DSG ( had since new)
Is a Carista hard to use ?
Generally, a steady orange light with no other warnings or error messages is something which isn't serious enough to mean you shouldn't drive the van. A flashing orange light means stop ASAP and get to a workshop.
I had the steady light a few months ago, kept going and coming back. Used ODBEleven (similar to Carista) to diagnose and came back as a stuck coolant valve. Was going to ring the dealer to book it in when got an email from them to say the van had notified them it had a fault!
Van went in a week or so later, was indeed a broken valve, all fixed under warranty. Van is a MY22 Ocean 150.
I used to use Carista, found it pretty straightforward, but switched to ODBEleven as gave me more options to customise things and turn on some features. In terms of using them for diagnostics, it's quite easy, plug the device in to the ODB port and follow the instructions in the phone app.
I would imagine , your van had not done a Regen for a while and it managed to complete the regen on the last journey, which would have turned the light off.
A good OBD scanner compatible for vw (not just Carista) will tell you what the fault code is , then you look the code up on line
Thanks, I’m going to keep the dealership booking and also look into purchasing a scanner.
There are lots, as @Perfectos says, but in general Carista is the cheapest and most frugal. Just get the free month and remember to cancel.
Had exactly the same problem/solution in our MY22 ocean 204.
Had Roadside VW technician out this morning. Did diagnostics check on why EMS icon showing and said “ cylinder 2 glow plug circuit” probably needs replaced, so call dealership”. Fair enough but Coil icon has not been staying on, so is this a fair assessment.
Booked in for the 14th, I’m wondering if dealerships will want to carry out another diagnostic and will it be under ‘All In Plan’ warranty. ?
Any thoughts. ?
