SqueakyWheel
T5 2015 DSG 4Motion.
2 weeks ago whilst out of the country, the ABS/traction control lights and tyre pressure warnings came up on the dash. Not much I could do at the time and it was initially driving normally. A week later, we did notice some acceleration hesitation and occasionally switched to manual gear changes, but made it home fine.
I've now run OBD2 diagnostics and it's reporting problems with 3 separate sensors ( both front and rear right ). I've cleared these, and the same errors come back after just rolling back and forth on the driveway. Just wondering how likely it is that all 3 have failed in the past two weeks before I order these? Presumably if there were wiring issues or the ABS unit itself, I'd see failures from all 4 sensors?
I'm still running the original 10 year old starter battery, so I'm going to pick up a replacement today. I've seen some threads reporting false errors due to low battery voltage?
U0415 [0xC415]
Invalid data received - anti-lock brake system (ABS) control module
Status: Pending
03. ABS control unit03. ABS control unit
DTCs: 4
00287 [0x011F]
Rear Right Wheel Speed Sensor-G44; Rear right speed sensor-G44
Status: Test is inhibited by other DTC, Validated and stored in non volatile memory
00283 [0x011B]
Front Left Wheel Speed Sensor-G47; Front left speed sensor-G47
00285 [0x011D]
Front Right Wheel Speed Sensor-G45; Front right speed sensor-G45
00668 [0x029C]
Vehicle voltage, terminal 30; On-board voltage terminal 30
Status: Pending fault present during this driving cycle, Validated and stored in non volatile memory, Validated fault present at time of request
01. Engine control unit01. Engine control unit
DTCs: 2
12888 [0x003258]
U041500: Invalid Data Received From, Anti-Lock Brake System Control Module
Status: Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
04278 [0x0010B6]
Status: Test failed, Test failed (current drive cycle), Pending, Test failed since last DTC clear, Warning indicator requested
DTCs: 2
12888 [0x003258]
04278 [0x0010B6]
U0415 [0xC415]
Status: Pending
DTCs: 4
00287 [0x011F]
00283 [0x011B]
00285 [0x011D]
00668 [0x029C]
DTCs: 2
12888 [0x003258]
04278 [0x0010B6]
DTCs: 2
12888 [0x003258]
04278 [0x0010B6]
