Oil pressure regulation valve and Heater support pump DTCs
jakubklapka
Prague
T6.1 Ocean 150
Hello, recently, my MIL indicator lit up and once I got my simple OBD reader out, I was presented with this:
01. Engine control unit01. Engine control unit
DTCs: 2
27228 [0x006A5C]
P165F00: Oil pressure regulation valve, Short circuit to ground
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
27173 [0x006A25]
P16BF00: Heater support pump, Short circuit to ground
Status bits: 1
Priority: 2
Frequency: 1
Unlearning index: 255
Odometer: 58151 km
Date, time: 2026.07.14 23:20:42
Engine RPM: 1160 rpm
Calculated engine load value: 46.67 %
Vehicle speed: 14 km/h
Engine coolant temperature: 90 ℃
Intake air temperature: 18 ℃
Barometric pressure: 96 kPa
Klemme 30 voltage: 13
Paramteric values: 20 96 28 44 84 24 C9 44 83 00 00 44 84 24 C9 44 8C 25 1C
To my surprise, I have not found anybody dealing with this, especially the combination. Since both came on together, I doubt that either the valve or pump failed at the same time. So maybe I'm dealing with some cable damage? Or does anybody have an idea what this could be? What troubleshooting steps would you recommend? I've drove multiple times with it without noticing anything unusual.
T6.1, MY2019, 2.0 110kW, 4MOT, DSG, CXFA.
Thank you for any ideas!
They could just be erroneous errors of no significance, especially as you have no drivability changes.
I would delete the Diagnostic Codes.and see if they come back in the first instance.
