P24C6 - Manufacturer-specific code
Gecko_Bioyag77
Gecko_Bioyag77
Dublin
T6.1 Ocean 204
Hi, hoping that someone has some advice on an engine warning light which came on this evening for my T6.1 California MY23, a 204hp DSG. I restarted the the engine to see if it cleared but it’s still there so going to contact VW garage in the morning as its still under warranty. I ran a scan using Carista to identify the engine fault issue/error, it seems to be a P24C6 sensor / circuit that has failed, see info below which appears to be the Particulate Matter Sensor. Hopefully this is straightforward replacement as the van has only recently been serviced and I had the 6oK DSG transmission oil change too, however VW updated the ECU software when it was in the garage I so hope the engine fault issue is unrelated. I assume the van should not be driven, even though it is not currently in limp mode and seems to be running fine other than the warning light.
Thanks,
Graham
Freeze frame :
Engine rpm: 1546 RPM
Air mass value: 21.58 g/s
Absolute throttle position: 83 %
Calculated load: 18 %
Coolant temperature: 79 °C
Vehicle speed: 44 km/h
Intake air temperature: 12 °C
Time since engine start: 1233 sec.
Commanded EGR: 89 %
EGR error: 3.91 %
Fuel level input: 90 %
Ambient air pressure: 101 kPa
Battery voltage as seen by the engine ECU: 12.1 V
Relative throttle position: 100 %
Outside temperature: 10 °C
Absolute throttle position D: 25 %
Absolute throttle position E: 25 %
Commanded throttle actuator position: 100 %
Engine oil temperature: 77 °C
Accelerator pedal position sensor: 13 %
Engine torque: 18 %
P24C600 - Particulate Matter Sensor Temperature: Circuit
Freeze frame :
Priority: 2
Malfunction frequency counter: 15
Unlearning counter: 40
Odometer reading: 60163 km
Date: 08 Mar 2026 01:55:29 p.m.
Engine rpm: 1545.5 RPM
Normed load value: 18.4 %
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.1 V
