1Pearman
Hi, having fitted my own solar setup to my previous vans (not Cali's) and reading up on how it should be done for the T6.1 Ocean i've fitted a Victron 100-20 MPPT under the front passenger seat with the positive going to one of the leisure battery terminal connections, and the negative going to the chassis side of the battery monitor (I drilled a hole for the connection bolt through the large silver part between the earth cable and the battery monitor). I'm then going to route the solar cables under the van into the engine bay for a plug connection in there for a portable solar panel setup. I tried it out quickly at the weekend and found it charge fine and whilst the Cali display showed a positive AMP input, the 'hours remaining' seemed strange and went from >60h to something like 6h when i connected the panel up. I think this also turned my fridge off to protect the batteries because I noticed it was off later in the day when i went to get some food out. Just wondered if there's anything wrong with how i've connected it or if anyones seen the display do this before? Most people go to the rear battery but because I want the connection in the engine bay I've used the front one.
