reserves
Have you tried it with the engine running?
Yes, should have said. Same result
If at home plug in EHUYes, should have said. Same result
As per previous fuse diagram SC 55 ...Thank you. Been out all day (kids birthday) so haven’t had time to check the fuses.
This is my fuse box (behind the bottle compartment drawer) not sure how it relates to the above but I’m happy to check each 5A fuse individually as I’ll be pleased if this fixes it.
Thank youc very clear.
Worth taking out the control panel unplugging the connectors then plug them firmly back in and refit the control panel then try the roof!
Are you sure your starter battery is full charged. People have reported in the past the same problem that you have and it was down to needing a new starter battery.Going to test the fuses & feeds.
Count down, 5 days till France!
Looks like SC56 is the fuse for the ECU which is fed from the ignition starter switch so you may still have an issue with your ignition switch, you may need an electrician or @Loz may be able to help further??? Hope you get it sorted!Thanks for this.
I seem to have an issue with *SC56* whilst SC55 is fine
There is no power going to SC56 either side of the fuse, regardless if the ignition or engine are on.
I know the ignition switch is working as SC55 only powers when ignition is on.
Thanks! Running out of time and patience!!Looks like SC56 is the fuse for the ECU which is fed from the ignition starter switch so you may still have an issue with your ignition switch, you may need an electrician or @Loz may be able to help further??? Hope you get it sorted!
@miata63 If you take a picture of the "Hardware Menu", in the same menu as the Diagnostics one.dear All,
recently I experienced a similar error in my T5 cali '06, the roof won't open or close, no errors in CU unit but when I try to open the display says: Ignition on? the vehicle is stops?
nothing can do for move the roof, ignition on, engine running, always same message and no movements.
all the other service run perfectly, only roof problem are present, I have move the roof by direct power supply to the pump and roof move perfectly, when is open there is the confirm on the display, the same when it is closed, so, all the sensor are fine (no errors in the diagnostic page).
I think there is some problem in electrical wiring but don't find the wiring scheme, the fuse are all fine and apparently no problem in a wiring loom under the seat near the battery.
someone experienced this and/ or have some suggestions?
Thanks for reply!
In attachment the picture of my debugging, Shft 2 say E5, what means?
ok thanksSo the Ignition Feed is missing - on a T6 this would be Fuse SC34
I don't have T5 circuits, but it will be the feed that goes into Component E153 (Camper Panel), T32b Pin 30.
