Hebridean
2015 VW Ocean with the display showing ignition? on when attempting to raise the roof. Reset the display, VW diagnostics showing no errors, checked the fuses, disconnected reconnected the engine battery all to no avail. The engine and leisure batteries are new and showing 100%, with the heater and fridge working as normal. I connected up the obd2 fault reader and came across two faults showing in the Electronic central section which have never been there before. 1) Terminal 30 turn signals and brake lights and 2) Implausible signal ignition starter switch. I tried to erase them but number two won't erase which I think is linked to the turn ignition on when trying to raise the roof.
On reading through the forums I'm thinking it's a roof sensor issue and how to go about changing them which I fear is a job too far for me to contemplate. I live in the Outer Hebrides and doubt there's anyone local who is familiar with the issue who can change out the sensors so I'm thinking a mainland trip will be needed.
I've been reading about Kernow Transporters Ltd who do this fix but they're at the other end of the country! So I'd be grateful if anyone could recommend a company in Scotland that can do this work.
Many thanks.
Many thanks.
