Roof Won't Open - "Ignition On!"
Blue 5A
SC55 5A BCU, Camper Control unit (key inserted feed)
Thank you. Been out all day (kids birthday) so haven’t had time to check the fuses.
This is my fuse box (behind the bottle compartment drawer) not sure how it relates to the above but I’m happy to check each 5A fuse individually as I’ll be pleased if this fixes it.
As per previous fuse diagram SC 55 ...
Worth taking out the control panel unplugging the connectors then plug them firmly back in and refit the control panel then try the roof!
Didn’t work unfortunately
Going to test the fuses & feeds.
Count down, 5 days till France!
Are you sure your starter battery is full charged. People have reported in the past the same problem that you have and it was down to needing a new starter battery.
The ignition switch can cause this issue, try giving it a good spray with an electrical contact cleaner then leave it a while before turning on. When the key is inserted turn it off and on a few times slowly and hopefully the fault will go but it could be intermittent then a new switch may be required.
Thanks for this.
I seem to have an issue with *SC56* whilst SC55 is fine
There is no power going to SC56 either side of the fuse, regardless if the ignition or engine are on.
I know the ignition switch is working as SC55 only powers when ignition is on.
Thanks for this.
Looks like SC56 is the fuse for the ECU which is fed from the ignition starter switch so you may still have an issue with your ignition switch, you may need an electrician or @Loz may be able to help further??? Hope you get it sorted!
Thanks! Running out of time and patience!!
I tried bridging the power from 55 to 56 and test the roof but no change.
It’s a mystery!
Just tested again and SC56 goes 'live' when starting the engine, so I think it's a red herring here.
For reference the 5 amp fuse, 5th down in the middle row is in the wrong place, should be one up (4th row)
This didn't fix my issue, but just in case anyone has issues.
I've still not resolved this, however I do have some further info.
The fuse that (as far as I can tell) is responsible for dealing with the ignition live for the control panel is circled in red below:
I know this for sure as I know have a working Cali with a working Cali roof.
Removing this fuse (SC34) from the working Cali causes the control panel to report the same 'Ignition On? vehicle Stationary?’' error.
With some help from the very helpful @vbk1975 I've managed to confirm this issue using the control panel diagnostics.
So it seems the fuse box knows the ignition is on correctly, however the control panel doesn't.
I have no idea how the information gets passed from the fuse box to the control panel, any ideas greatly appreciated :)
Fixed!
Unfortunately do not know exactly what caused it.
If anyone else finds themselves in this situation with the ‘Ignition On? vehicle Stationary?’ error then I'd do the following:
Check the 5amp SC34 Fuse in the fuse box behind the bottle holder. This should have power when the ignition is switched ON.
If this is working then I'd remove the front passenger seat (the one with the leisure battery) check all the fuses here and then unplug all the large connectors, check for any loose wires, give them a spray with switch spray if you'd like.
Connect them all back again and try the roof again.
dear All,
recently I experienced a similar error in my T5 cali '06, the roof won't open or close, no errors in CU unit but when I try to open the display says: Ignition on? the vehicle is stops?
nothing can do for move the roof, ignition on, engine running, always same message and no movements.
all the other service run perfectly, only roof problem are present, I have move the roof by direct power supply to the pump and roof move perfectly, when is open there is the confirm on the display, the same when it is closed, so, all the sensor are fine (no errors in the diagnostic page).
I think there is some problem in electrical wiring but don't find the wiring scheme, the fuse are all fine and apparently no problem in a wiring loom under the seat near the battery.
someone experienced this and/ or have some suggestions?
Remind me tomorrow and I’ll dig out those debugging instructions
dear All,
@miata63 If you take a picture of the "Hardware Menu", in the same menu as the Diagnostics one.
Looks like this (Credit @reserves)
From this I will try and work out what is going on
Thanks for reply!
In attachment the picture of my debugging, Shft 2 say E5, what means?
Thanks for reply!
So the Ignition Feed is missing - on a T6 this would be Fuse SC34
I don't have T5 circuits, but it will be the feed that goes into Component E153 (Camper Panel), T32b Pin 30.
ok thanks
unfortunately, the fuse layout of the T5 is different from T6 and don't find the same fuse protection circuit (eg. ignition feed or other like this)
My fuses are all ok, but obviously, I don't know if there is one of that who is not supplied for some reason (broken wire or other issues)
now have realized external circuit whit 2 relays and one doble button that supply the pump of the roof, this bypass the problem but I am extremely curios to find the problem and return to original VW system.
