Max-Felix
Planning this at present but having read quite a few topics that show this fitted, can those who have done it please help with the following:
Most seem to stick the ribbon to the inner (van side) casing of the awning and continue round to the inside of the awning arms - can you describe a little more how this works out - ie allowing excess for the bend of the awning support arm hinges? How durable the adhesive backing is? If repeated flexing at the awning arm elbows etc causes any issues?
Is there decent clearance (any?? - looks to me like it would be crushed?) when the awning is fully closed between the case/arms/led ribbon?
I've got a 5m ribbon on the way and plan is to run say 3.5m of this with the terminal end at the LH end of the casing (ie by the tailgate top corner) along the inner casing and inside the RH arm (around the elbow) and then run the remaining 1.5m in a separate piece from the same LH point all along and inside the LH arm. Both connections then doubling up in one termination. Any thoughts? I've no issues with the power supply and routing but more concerned with the ribbon part.
