This may help.Hi everyone!
I’m Aron Klaus Frey and i need your help.
I have just bought a T6 California Ocean and the latch on the under-seat drawer is misaligned (like on the picture).
Is it possible to dismantle the latch and realign it?
Thanks for the pieces of advice in advance!
Best wishes,
Klaus
Thanks a lot for this diagram! It will surely help when i get to the job.This may help.
Personally I would just lift it up and push it to the Right until straight.
It will be a lot easier.Thanks a lot for this diagram! It will surely help when i get to the job.
In the meantime, i have found a thread with the same question.
The owner dismantled the latch and had difficulty to put it together.
So i may try to bend it on spot
Hi, I have the same issue. I've tried the lift and bend to no avail. If you do get it sorted I'd appreciate any tips. Than you!Hi everyone!
Best wishes,
Klaus
And me! Tried to lift and bend without success.Hi, I have the same issue. I've tried the lift and bend to no avail. If you do get it sorted I'd appreciate any tips. Than you!
I tried to realign it by pushing back to its original position. No success. I mean, I don’t want to break the lever.Hi, I have the same issue. I've tried the lift and bend to no avail. If you do get it sorted I'd appreciate any tips. Than you!
