thomasamoht
T6.1 ocean rear leisure battery cupboard, can it fit a L36-AGM 353L x 175W x 190H mm through the hole? It looks like the holder can take it. Its tight and I’ve already ordered the battery!
You do realise the leisure batteries should be identical in chemistry and electrical power and replaced in pairs. The battery you mentioned might fit in the rear , although it is 4cm longer. I doubt if it will fit under front seat so you will have 2 mismatched batteries.Well I’m going to have to find a way! I’m sure someone must have tried this?
There always is. I think deep down I know the answer but I’m stubborn and will probably just scrape my knuckles tryingIm sure someone will be along shortly to confirm if it will.
