ddgp
Hello everyone,
I need to replace the auxiliary batteries in my T6.1 California Ocean.
After 6 years, my two AGM batteries don’t seem to be performing as well anymore, which I guess is normal.
My current batteries are 75 Ah AGM, 315 × 175 × 190 mm.
I’m considering two options:
Option 1 – Stay with AGM
Option 2 – Switch to LiFePO₄
Thanks guys.
(If this has been discussed in another thread please feel free to point me out to the right thread)
- Replace the two original 75 Ah batteries.
- Q1: Is there a higher-capacity AGM that fits the same dimensions?
- Q1.1: If I replace them myself, do they need to be registered/coded, or can I simply swap them?
- Q1.2: What exact AGM model would you recommend?
- Replace the two AGMs with one larger LiFePO₄ under the driver’s seat, plus a DC-DC booster.
- Q2: What is the largest battery that can realistically fit there?
- Q2.1: What exact battery model have you successfully installed in a T6.1 Ocean?
- Q2.2: What additional cables, fuses, charger/booster, etc. are required?
Thanks guys.
