E
ElectronicEquipmentRepair
VIP Trade Partner
Topic marked as SOLVED - we have gathered the info we were looking for, thank you!
Hi everyone...
I'm not sure where I should post this thread, so mods please feel free to move it
I’m doing some investigation into how the VW California camping control unit monitors and controls the electro-hydraulic roof, and I’m looking for some information from owners with correctly working roofs.
I now have enough information to simulate control of the roof system on the bench and can reproduce a number of different roof states. What would be particularly useful is to compare my bench results with the values reported by control units fitted to working vans.
I am not asking anyone to take voltage measurements, remove the control panel, disconnect anything or probe any wiring. All I need are some photos of the control panel's built-in diagnostic screen while the van and roof are in several different states.
Accessing the hidden hardware/debug screen
On the camping control unit:
Press the centre of the rotary control/SELECT button to bring up the normal menu.
Press and hold the BACK button and the centre of the rotary/SELECT control together for approximately 3 seconds.
A hidden menu should appear.
Select Diagnostics.
Select Hardware Menu.
This displays the internal analogue/debug values as AN0, AN1, AN2 ... AN9 as well as digital input states SHFT1 and SHF2.
I'm interested in seeing a clear photo showing the complete Hardware List would be much more useful than just writing down those two numbers.
What I would like to collect
If you have a California with a normally working electric roof, could you take a photo of the Hardware Menu in as many of the following conditions as is convenient:
Roof fully CLOSED, key removed, ignition off
Roof fully CLOSED, key inserted, ignition off
Roof fully CLOSED, ignition on
Roof approximately HALF OPEN, key inserted, ignition off
Roof approximately HALF OPEN, ignition on
Roof fully OPEN, key inserted, ignition off
Roof fully OPEN, ignition on
If possible, it would also be useful to know:
Van model/year:
Control panel type/part number, if known:
Roof position: closed / partly open / fully open
Key: inserted / removed
Ignition: on / off
Then attach a photo of the Hardware Menu screen for each condition.
There is no need to operate the roof with the ignition in a state in which the van would not normally allow it. The idea is simply to position the roof normally, then look at the diagnostic values under the different key/ignition conditions.
Why I'm interested
The control unit has two internal analogue readings associated with the roof system, AN8 and AN9. I have been investigating how these inputs are interpreted and have been able to reproduce different roof indications on a control unit on the bench.
For example, I can produce states corresponding to roof open, roof closed and an intermediate/part-open roof position. What I don't yet have is a good set of reference readings from several known-good vans showing exactly what the control unit sees in real-world conditions.
I'm particularly interested in whether the readings are consistent between vehicles, how much they vary, and what changes when the key/ignition state changes.
Even one or two photos from a working van would be helpful, so don't worry if you don't want to go through every combination above.
Please don't dismantle anything or take electrical measurements for this – the information available from the built-in Hardware List is all I'm looking for.
Thanks – I'll collate the results and, once I've got enough examples, I'll post what I find about how the roof inputs and control logic appear to work.
Hi everyone...
Select Diagnostics.
Van model/year:
Ignition: on / off
Why I'm interested
