Souter
Decided to check roof drain holes as have had our T7 Coast since february and have been away in it for the past 7 weeks.
Checked them both for gunk and cleared as much as I could.
Then poured hot soapy water into each channel-both blocked!
Didnt have anything that I could use as a small tube to blow into the holes but managed to cover the access with my mouth ang give them a good blast of breath. Did the trick after a few goes!
The access to the drain hole is not good as it’s under lip of the front roof panel.
Syringe and tube order being prepared for future use.
