Roof Drain Holes
Souter
Souter
UK/FR
T7 ocean
Decided to check roof drain holes as have had our T7 Coast since february and have been away in it for the past 7 weeks.
Checked them both for gunk and cleared as much as I could.
Then poured hot soapy water into each channel-both blocked!
Didnt have anything that I could use as a small tube to blow into the holes but managed to cover the access with my mouth ang give them a good blast of breath. Did the trick after a few goes!
The access to the drain hole is not good as it’s under lip of the front roof panel.
Syringe and tube order being prepared for future use.
I don't know if I would use soapy water to clear the drains.
I just use clear water that I pour through the holes with a syringe.
Flushed mine out with a syringe last week, front and rear drains. Flowed freely, and it’s the only time I have ever done it since purchase in 2010.
Why not, a mild soapy solution won’t do any harm. I put 2 drops of Fairy Liquid in 1.5 litres of water.
Avez-vous une photo pour m'indiquer ou se trouver les orifices de nettoyage
cordialement
cordialement
Bonjour
Désolé, non, j'ai oublié de prendre une photo, mais ils sont faciles à trouver. Il y en a un dans chaque coin avant, sous le panneau de toit avant. Il vous faudra un escabeau pour monter assez haut afin de les voir. Ce schéma pourrait vous aider.
Cordialement
IMG_2178.jpegaider.
Good to see VW carried most of the bad things over from the 6…….and none of the good ones!
