G
Grass verge 13
On my Ocean (2022) the right hand stove gas knob has seized and does not move up/down/twist. Thankfully it is the one that we least use so decided to have it looked during the next service.
Is this common if it does not get used that often, probably less than 20 times in 4 years. We have had it rom new and the left one gets used loads and is fine.
I do have the extended warranty and booked into Breeze in November coming from Bristol as we see typically good things about the dealership. What concerns me a little is that they say that if VW refuse the warranty claim then there is a £160-ish inspection fee that I'll pick up so thought I check here if (a) it is normal for these to seize when used infrequently (b) has anyone else seen this (c) is this likely to be rejected as a warranty claim?
I'd be disappointed if we have to pick up the inspection cost without a fix so wondering if it is a complex fix.
The stove top is never left dirty and just wiped around after use but not left covered in water. It does look okay just rock solid.
