So to summarise where I think we are at,
The T6 Quasimodo (new style) rack is super simple to undo. Access to the securing bolts could hardly be easier.
It comes with some attempt at security bolts, but as they are all the same (seemingly), it would be very easy to go equipped. Access is very easy. Replacing each of those bolts with different unusual heads will challenge the thief further, but access to the bolts remains easy.
The T5 and the rare T6 Kylie racks are also vulnerable, but there is much less room for the thief to work in and the bolts aren't immediately visible (But still alarmingly easy access!)
With the standard supplied hex bolts fitted, they can be undone with the short end of an allen key (not the long end or the supplied tool). Adding security bolts to them may make these models doubly more difficult to steal as the right head would be needed but more importantly, the size of the head might make access impossible. If that's true, then brute force would be required.
Upshot - If you are leaving either rack on your van secured with standard supplied bolts, you are taking a high risk. If you have the Quasimodo and standard bolts....well, I'll leave those words to you.
