Masher
Could anyone help please with some basic questions about the electric roof emergency lowering? In my case it's a 2023 6.1 California Ocean.
Once you have unclipped the overhead panel, how do you find the magic pressure release screw? I watched the "California Chris" video on how to do it and he drops the panel to reveal a load of insulation foam hiding what I presume is the pump but doesn't go on to show the whole procedure. Do you have to tear all of this foam out to find the screw or just keep poking your screwdriver through the foam in a specific location to find it?
Is it obvious which screw when you see it or are there several? (don't want to end up with a shower of leaking hydraulic fluid or something by turning the wrong screw)
After lowering, can you just retighten screw and attempt to raise again with the pump or must you top up fluid something?
I was in need of this procedure recently when I had a really bad sagging issue on the passenger side (my van is just 2 months outside of its 3 year warranty). I was just about to leave the campsite and couldn't get the roof to straighten up before closing - even after trying to raise it first to level it up. It immediately dropped again on the passenger side.
I looked in the manual but couldn't get my head around the section about the override procedure and stupidly had no tools to hand either. In a bit of a panic I ended up trying several times using the motor to close the roof with one side being much lower than the other. there were a couple of very unnerving clunks..... I'm dreading what's happened underneath but it closed and locked ok without any obvious damage from the outside to be seen.
I've been searching for a video showing this procedure but can't find anything. It would be great to get a step by step from someone that has done it.
Next step is to book in for a diagnostic and repair - I'm hoping it just needs a ram replacement on that side. Has anyone had any recent good experience with an independent or dealer? I'm just North of London.
A few of the recommended people on here have stopped trading. The favourite seems to be Kernow Transporters in Cornwall but it's 300 miles from me. I saw another person used Links Automotive in Macclesfield and someone else used Bognor Motors on The South Coast.
I'd be really grateful for any recommendations on someone very experienced with VW roof systems.
I believe the pump is very expensive and the cylinders (rams) too, so I don't want an inexperienced mechanic or dealer just endlessly throwing new parts at it until it's fixed and then racking up a massive and unnecessary bill.
Thanks!
Thanks!
