Help with electric roof manual lowering procedure
Masher
Masher
East Anglia
T6.1 Ocean 150
Could anyone help please with some basic questions about the electric roof emergency lowering? In my case it's a 2023 6.1 California Ocean.
Once you have unclipped the overhead panel, how do you find the magic pressure release screw? I watched the "California Chris" video on how to do it and he drops the panel to reveal a load of insulation foam hiding what I presume is the pump but doesn't go on to show the whole procedure. Do you have to tear all of this foam out to find the screw or just keep poking your screwdriver through the foam in a specific location to find it?
Is it obvious which screw when you see it or are there several? (don't want to end up with a shower of leaking hydraulic fluid or something by turning the wrong screw)
After lowering, can you just retighten screw and attempt to raise again with the pump or must you top up fluid something?
I was in need of this procedure recently when I had a really bad sagging issue on the passenger side (my van is just 2 months outside of its 3 year warranty). I was just about to leave the campsite and couldn't get the roof to straighten up before closing - even after trying to raise it first to level it up. It immediately dropped again on the passenger side.
I looked in the manual but couldn't get my head around the section about the override procedure and stupidly had no tools to hand either. In a bit of a panic I ended up trying several times using the motor to close the roof with one side being much lower than the other. there were a couple of very unnerving clunks..... I'm dreading what's happened underneath but it closed and locked ok without any obvious damage from the outside to be seen.
I've been searching for a video showing this procedure but can't find anything. It would be great to get a step by step from someone that has done it.
Next step is to book in for a diagnostic and repair - I'm hoping it just needs a ram replacement on that side. Has anyone had any recent good experience with an independent or dealer? I'm just North of London.
A few of the recommended people on here have stopped trading. The favourite seems to be Kernow Transporters in Cornwall but it's 300 miles from me. I saw another person used Links Automotive in Macclesfield and someone else used Bognor Motors on The South Coast.
I'd be really grateful for any recommendations on someone very experienced with VW roof systems.
I believe the pump is very expensive and the cylinders (rams) too, so I don't want an inexperienced mechanic or dealer just endlessly throwing new parts at it until it's fixed and then racking up a massive and unnecessary bill.
Thanks!
View attachment 150526View attachment 150527
Thanks!
Make a trip to Cornwall very experienced, campsite opposite well worth the extra mileage, went there last month from Berkshire.
If booking campsite ring up tell them you are booked in with Kernow transporters and they will do 1 or 2 nights, as website says minimum of 3 nights.
I'm not certain about the 6.1... in my 7.0 Ocean, the pop top hydraulic pressure release screw is in the back on the right. I thought the 6.1 was located there too, but maybe best to wait for a reply from someone who actually knows for sure.
Thanks!
Here you go:
Here you go:
Brilliant! Thank you
Thanks for showing this, I'm just wondering if anyone knows how much fluid is released when the screw is undone, and do you just put a yoghurt carton, or larger tray under it to stop it staining the inside of the cab?
No fluid should be released.
Just to confirm you just undo the screw a few turns. It cannot be removed unless you force it as it is a captive screw.
Thanks!
Not had this issue but have used Links in Macc for our Cali for yearsince a bad main dealer experience and would trust them to work on the raising roof
Thanks!
Hi just seen this. You mention Links in Macclesfield, I would reccommend them and trust them completely, have used them for years and I'm sure they'd have a chat with you to see if it's worth the trip to see them. On another note, we have had just two mechanical issues in 12 years of ownership and both happened whilst holidaying in Germany. There the VW car dealers, which seem to be on every corner, work with the California every day and both times our issues were diagnosed and fixed in no time, same day and next day. So whilst not much help with the current issue, if anyone has California technical questions and is ever with the vehicle in Germany the dealers seem incredibly knowledgeable, keen to help, and competitively priced.
Thanks!
*****Update*****
I decided to go with main dealer in the hope that I could get a contribution from VW.
So far they have followed all of the diagnostic measurements and tests over several days - as well documented elsewhere on the forum, and they agreed that it is quite bad.
Next step (also well covered on here) is to swap hydraulic lines at pump. This will incur 5 hours of labour charge so already getting expensive before any fix is in sight.
I will keep this updated.
H
That’s a lot of money just to find out what is wrong. It might be worth getting a price off them for replacing the pump without bothering with the diagnostics.
Chances are it’s the valve in the pump allowing fluid past.
For the cost of the diagnostics you could get the van transported down to Kernow and get the fix done properly at a reasonable cost.
H
Yep, I know…..it’s a tricky one.
It’s a fair bit more to get it replaced at an independent though TBH and I’m hoping for a contribution from VW and it would also have a guarantee in case it goes again.
I completely agree it’s likely the non-return valve but if I ask them to replace the pump without doing the diagnostic and then it does turn out to be one of the hydraulic rams on the roof then it’s probably going to be another £1000 or more to replace those.
Thanks!
I have a 2005 California T5. The overhead control panel looks about the same. After prying it off, there is ( in my case) a small seeming metal circuit board ( or something equivalent hiding the screw, that you have to push aside. The brass screw with atop for a flat head screwdriver, is partially hidden near the bottom edge of the hole left by the removal of the control panel. It's not very obvious or visible, but it's there. The photo below does not fully locate it. It is closer to the lower edge of the holeThis is not the location of the hydraulic motors, it just releases the hydraulic pressure. It took me about 3 hours of time originally to find it,.. but now that I know where,.. it's a snap. Some comments have been turn the screw 1/2 turn counterclockwise to release the pressure, I rotated it a number of turns 2-3. The danger is that if the screen is turned too much that it comes out,.. bigger problem . Once turned, the roof came down gently, fully. - Rainer
*****Update*****
*****Update*****
Left and right hydraulic lines swapped. During the swap over there was a large amount of air released and it took a few seconds before any fluid appeared. The roof has been up for more than a week now without any sagging.
My concern is how so much air got in to the system and if it will happen again at some point. It must have been quite sudden because for a long time I had no issues at all - it wasn't like it gradually got worse. I was on a recent trip and it sagged a couple of inches over the whole day and on the next trip a week later it sagged by a huge amount on one side within seconds of raising the roof.
Strange that is now seemingly ok..... maybe the fluid level was low and it gulped in some air but it has never been operated on a steep slope or anything. I will ask the service tech.
Please keep us posted. It's important that us as owners have as much info on this subject as possible, because the dealers certainly don't seem to know what to do.
