Help high pitched alarm type noise coming from back of 2011 California leaving for hols in the morning!
ardvark
LEWES east sussex
T5 SE 140
Morning would really appreciate some help on this please. We have a high pitched alarm type noise coming from the rear of our 2011 California. We had thought it was an aircon canister leaking but it’s still going 24 hrs later. We are supposed to be leaving for Belgium in the morning and have no idea how to stop it.
Any help gratefully received. Could it be the leisure battery it’s very low not used much though. We are charging it at the moment but it’s not helping matters. Maybe it’s something else at the rear? Sounds like an alarm. With everything closed for BH not sure what we can do.
Thank you
Any change you could upload it so we can hear?
Any warnings on the control panel? What’s the voltage of the leisure batteries?
My bet is it’s them that’s causing the issue.
Thank you
Is it the water pump? Turn tap On/Off.
Hi no change I’m afraid. Have been trying to
See if I can upload a video but can only upload photos as far as I can see
Nothing on the control panel. How can I check the voltage of the leisure battery? Please
We have taken out every fuse and it’s still going it appears to come from the right rearside
Does it go with the engine running?
Search the for a Welsh gas post giving details how to access the engineers page on your control panel - it hopefully will show the fault there.
Do you have a tow bar with aftermarket wiring by any chance. There will be a small alarm buzzer type thing which should work with the indicators when a trailer is connected. Could be the culprit if it’s gone faulty.
These are the fuses on my Cali but position can vary so check all the options shown in the photo
Thank you so much I think it is the cigarette lighter. This is so thoughtful and extremely helpful thank you
