The easiest way to connect a 2nd leisure battery is as follows.You’re all welcome! It’s a pleasure.
Now, I would be happy to receive detailed input on where the N162 relay is located on my Cali SE -05. Or if there’s a better connection point for a rear leisure battery (i.e directly to the charger?). Maybe if someone with the same model year could have a look.
Thanks!
2nd battery -tve to chassis.
Then connect the +tve pole to the +tve pole of your original battery via a 75amp cube fuse on the +tve pole of the 2nd battery. Use 2AWG wire for the connection.
