You will most likely be told that each vehicle is unique to its configuration, so unlikely to have one specific to your vehicle.Hello,
Does anybody have facelift model house department fuse diagram?
Funny you should say.Asking an authorized service would have been my next step, and based on this information, it seems to be the only way to get a fuse diagram that is correct.
Our water pump stopped working, a message appeared on the screen next to the bathroom that some safety mechanism had been activated due to lack of water, even though there was about 80 liters of water. So to reset the fault message, I would have had to find the right fuse, now I removed everything one by one. Yes, that also reset it and I got the pump working, but the right diagram would have helped considerably.
In addition, we have also had enough other electrical problems, e.g. the starter battery did not last a week without being discharged. But after a few recalls and other warranty services, the faults have decreased. But a newer car would probably work more reliably...
Yes… the old ‘big red’ switch and blue connector fixes seem to have zero effect on this van.Sounds very familiar, we probably had an airlock at first, which prevented the pump from being used by the protection. It hasn't happened since, at least not yet, but we're waiting for it.
First we tried disconnecting and reconnecting the "blue switch", which is apparently a universal fix for almost any electrical problem on pre-facelift cars, but it had no effect on the reset.
Same here, unfortunately.Yes… the old ‘big red’ switch and blue connector fixes seem to have zero effect on this van.
