Interesting, does that fit in the cupboard then?http://www.ebay.co.uk/itm/Compact-P...445?pt=LH_DefaultDomain_3&hash=item20fb40e83d
the single burner stove shown in earlier post are also made in compact size we had one same as larger one but to pack up you need to remove gas canister
Yip.
I'll know in a day or two, saw the "Yip" and thought that meant it fitted so ordered itMotocyclist, Re compact single burner ring fitting in rear locker cant say for sure if in would in the case as we have passed ours on but they are noticeably smaller if intrested you could try emailing a suppliers there are several on eBay
Yes it fits! Easily ....Motocyclist, Re compact single burner ring fitting in rear locker cant say for sure if in would in the case as we have passed ours on but they are noticeably smaller if intrested you could try emailing a suppliers there are several on eBay
We carry the small Cadec BBQ (Safari Chef) its ideal and very versatile. Its gas powered so no messy charcoal. I use a 907 gas cylinder so have backup gas as well.
Do not use a larger pan. I believe that this is what caused a cylinder to explode at our neighbours campsite 2 years ago, injuring 4 people. Exactly the same style of burner.There's a limit to the size of the pan you can use (I think they are playing it safe with that sticker, I will try a larger pan and see if the casing gets hot). In any case, you can slide the pan to one side slightly.
Anyway, could be a case of taking that or none at all if space was tight.
Good find that Andy![]()
http://www.dorsetecho.co.uk/news/10433821.Four_injured_in_explosion_at_holiday_park/
Thanks for the advice, I'll stick to small pans I think!There's also a heat deflector fitted between two of the pan supports, you can see it in the picture. Is that a new mod?Intresting the one 1 had did not have the sticker so reckon they have update following issue.
Unfortunately, after having used this cooker last week, I can no longer recommend it.Yes it fits! Easily ....
or ...
Mummy & Daddy ...
But
