Securing a T5 Pop-Up Roof Manually from the Outside
  • Thread starter The Lost Jockey
  • Start date
T
The Lost Jockey
Harrogate
T5 SE 174
I have been fretting about my pop-up top jamming when up and having to close it manually. I appreciate that checking and maintaining the hydraulics and like is key. I have also got the 'T5 Supplement for California'. On page 25, it describes using velcro tape and plastic rails to secure the pop-top: see picture. My van did not come with these things. Does anyone have these? If you don't have them, what would you use to secure the pop-up top? I realise this is being pedantic and over-cautious but you never know. I'd prefer to ask here than be stuck in remote Scotland and have to face the issue. Thank you for your help.
The emergency Velcro straps can be purchased from the Forum Shop, or just get a ratchet luggage strap long enough to go over the roof and through the front door openings, with doors open , and then close the doors
Sorry to be dense but can you give me a link to the Forum Shop? Or alternative. Thank you.
I bought a T5 California 3 years ago, have had issues with the pop-up roof not closing down, releasing it manually, and then confronted with a long drive.. I did what the other post suggested , a long strap with a ratchet that could be tightened, fed over the roof and through the front doors. However, lo and behold , in the drawer beneath the paas=ssenger seat I found 4 metallic slider/ adapters that go into the rails, along each side of the roof ( eg wherein the awning is secured) and have a grommet on them through which you can slide a strap to secure the top. That way no strap goes through the driver/ passenger front area. Where the previous owner got them,.. I don't know,.. but the metallic slider adapters seem made for the purpose. Rainer
My concern is not strapping it down, but getting it down in the first place.
Thank you for your help, everyone.
For getting down the roof, you need to locate the screw behind the central control panel. I have never needed to use it but that is what you need to turn to lower the roof if it is stuck.
With thanks.
