Leaky window frame ?
H
Hernan Morillo
Cambridge
T6 Ocean 204
After a very wet and windy couple of days at the Glen Brittle campsite in Skye, I’ve noticed a significant leak in my 2017 Cali Ocean..There is water getting in between the left side window frame (over the sink) and the body. The sliding window section does not appear to leak. The water drips can be seen behind the sink - dripping from bodywork- onto the middle and bottom shelves. The plumbing is all fine ( holding tank, hoses, sink drain and tap, all not leaking ). Any other reports of faulty / leaky windows in the forum? Grateful for any advice.
The photo shows the view with the slide-out cutlery tray removed.
Hi! I had the same issue, and in my case, it was caused by the sliding window drain. If you open the window and use a syringe to pour water into the small hole where the pin fits, you'll see that the water drips behind the sink. I decided to route the drain directly into the greywater tank. If anyone has the same problem, I can show you how we did it!
Yes please!
