T5….Both dipped beam lights not working……?
Nomad
Nomad
shropshire
T5 SE 174
Hi, away in the Alps….just discovered that both dipped beams are not working….seperate bulb for dipped and main beam… changed one bulb, not fixed. Checked individual 15 amp blue fuses. All are ok….California T5. 2008. Anyone got any recommendations for trouble shooting? Could it be rotary switch?
probably a silly question but have you tried replacing them? When i had one of mine fail, neither worked. This was for the main beams though.
T5.1 however cant see it being any different to a t5
Alternatively you could try removing the light switch and check for any corrosion or damage. its a quick easy check.
Thank you for your response. First thing I did was change a bulb. Difficult process fiddly clips and not being able to see. In daylight today will attempt a bit more problem solving. I have removed switch and checked terminals…last night was first time driving at night…usually in campsite by afternoon. ……thank you again
Ordered replacment rotary switch from a vw dealer in Zell. €130. Delivery tomorrow. More troublshhoting then. Daylight driving only for now. Ive seen some reference to a module ? Near fuse box that has something yo do with the headlamps ? All the fuses listed in the handbook have been checked and all ok. Thanks again.
Q. I cannot remember but does a green symbol appear when lights are powered on. Like the blue main beam. ? Only been driving it 18 years :(
Have you checked you are getting power to the light bulb connector ?
Any corrosion on the connector ?
Does the high beam work ? when using the stalk to flash / change from dipped to low beam ?
Edit halogen or Xenon ?
Ooooh parts cannon fired without proper diagnosis?
Sarcasm aside, usually this forum creates discussion and useful advice. When many hundreds of miles from home and on a timeline many of us do not have the luxury of workshop facilities or suchlike and all options have to be considered. Very lucky to find a mechanic and garage that looked at car next day….after removing air filter and other equipment acces to the rear of the bulbs was facilitated. The H7 bulbs had blown, both on only 1 filament. The H1 main beams then became inoperative? Seemingly all bulbs not working except 1 filament of H7 when main beams then became selected……wiring checked out and replacing both H7, dual pin, dual filament bulbs and reseating the H1 main beams all then worked as normal. What caused double bulb failure at the same time is a mystery……first ever headlamp bulb change in my 18 years since new and 130,000 miles…pa if the bulb retaining clip comes out of its holder and falls into engine bay just hope you can find it……I was lucky. Thanks again for any advice…
Glad you got it sorted :bananadance2
Filament bulbs are very sensitive to higher voltages, multiple bulb failures in a very short period can be indicative of voltage regulator issue. There can be many causes, so absolutely not saying it is this, but if it happens to other bulbs then it might be worth considering.
Amazingly I have just had the same happen to my California T5 , 2007. Both dipped beams gone. Full beam and sidelights and fog lights all working. Have yet to check fuses but seems strange they should both go simultaneously. I think each headlight is on a separate fuse anyway. Should there be a green light on the dash when they are working? I don’t recall either after 19 years :) . Given your experience seems like I should check the bulbs.
Just be aware you may be getting full beam but on the dipped bulbs…? Check all bulbs first..be careful with the clips…fuses are Easy to check, below gear knob. Best of luck.
Thank you again for your help. All resolved. I did check fuses but they were all good. Both bulbs had blown at the same time. An easy job to change them really. I do like retro, when you can still change a couple of bulbs for 12 quid! I think it may have had something with the freezing weather and how I turned them on, a funny movement with the rotary switch, who knows! Seems strange that both would go exactly at the same moment.
Maybe worth adding that on these dipped beam lights (H7), one will work without the other. I replaced one bulb, having checked the other and thinking it was still OK, and just the new one came on. So replaced the other.
