DocDave
Would be grateful for some advice - I am currently in France and since leaving england despite 2 refills the adblue MFD distance did not increase. I now have 1300 miles left on the display - probably enough to get back to the UK. However I went to the VW Van Centre in Brive and they kindly ran their diagnostics - they said they could not reset the system (despite trying) and that the ultrasonic sensor failure was most likely the cause.
On my way back to where we stay the DPF light came on - so on return i used an OBDII reader (Car Scanner) and found on the ECU fault codes a P218F00 error code that suggests no adblue is flowing out of the tank - perhaps injector blockage. This seems likely to me to have resulted in more soot in the DPF than usual hence the DPF warning light. I cleared the codes and the DPF light has gone off (but adblue still 1300 miles) The app also shows a calculated soot level (24g) but i cant find any "measured" soot levels in the app. I have read many of the helpful posts on the adblue issues but not sure what the dpf risks are here. We have done mainly motorway driving here - not short trips.
I expect the errors will recurr when I next drive it if their truly is no flow into the exhaust system. Do you think I can make it back safely to the UK on the autoroutes and will the regeneration system still operate (with no adblue injecting) to clear the soot? Or should I bite the bullet and take it back to the VW dealer which may involve a tank replacement and some delays. I am booked to return to the UK this friday...... All advice welcome.
Its a 2106 205 DSG California approx 55,000miles
David
David
