Intermittent failure to start
Graham
Graham
Hi hive mind.
I have a weird intermittent snag on my 2007 SE, as follows:
Unlock door <blip>
Turn key
Sometimes starts, (I have a nice full nearly new battery). Sometimes turns over but will not fire. Sometimes churns briefly then just stops.
If it doesn’t start, I take the key out, blip locked and unlocked, and try again.
Then it starts. Every now & again I have to repeat the lock/unlock cycle.
Has anyone else had a similar issue and solved it?
I can’t work out whether it is key, lock, immobiliser, starter solenoid, some random loom issue. I get the same with both keys, so probably not that. When it starts, it starts just fine. It’s intermittent & happens more when I use the van less. I can live with it as I know a workaround, but it’d be nice to fix it properly as I do like to turn off in long queues to avoid emissions & getting started again is red light roulette!
Many thanks.
Hi hive mind.
Unlock door <blip>
Turn key
Many thanks.
How old are the key fob batteries?
This...had this on my 2015....WG quite correctly highlighted fob battery which I had an inkling as its seemed to immobilizer the vehicle. Started / moved it across the road to load the vehicle/ wouldn't start / then started and I didn't want to take the risk, so swapped vehicles. Normally my other vehicles note when they are low....VW doesn't
I've only had that message on my Multivan " Key battery low ", never in 10yrs on the California.
Op stated he has the same issue with both keys.
And?
They could both have original batteries which could be 19 yrs old, unlikely I agree. Depends if both keys are used in rotation as primary key or batteries changed by previous owner or not.
