E
egena
California Ocean T6 roof repair - Roof will not open/close
TECHNICAL GUIDE
Symptom
When attempting to drive (ignition turned on) or to open the pop-up roof, the central Camping Control Unit (CCU) reports there is a "Roof Fault!", accompanied by audible beeps/pulses. The CCU also won't switch off, alerting that the "Roof is open!" when it isn't.
For the CCU to raise the roof, it needs to be aware of the position of the roof. It does this by using small magnetic sensors called Hall sensors.
There are two hydraulic rams, either side of the roof, that do the lifting and each ram has two of these hall sensors which report to the CCU what position the ram (and therefore roof) is in. The rams are operated by a hydraulic pump hidden behind the CCU, normally heard buzzing away when the roof works normally.
Despite being well covered, after several years the casing of the hall sensors begin to split and normal ambient moist air gets inside them, corroding the magnetic switch, stopping it from working. When this happens, the CCU is no longer aware of where the roof is positioned so, for safety, it blocks the ability to raise or lower the roof.
NOTE: Its good to consider that, even if this hasn't yet happened to your California, this is guaranteed to occur eventually and so it is good to be prepared.
Troubleshoot
The first thing that can be done is to check if the sensors have perished. To do this in the T6 California, the CCU has a secret menu where the sensor signal can be seen. To access this menu;
The two that are of interest are AN8 and AN9. Both of these will show a ZERO, when the ignition is turned OFF. When the ignition is ON, there will be a numerical value shown. In the case of faulty sensors it will show this;
When 255 is displayed, this means a sensor is not detecting the ram position. In normal operation, one of the sensors should be detecting the ram position but in this case, we can see that neither sensors can detect the ram; both "CLOSED" (AN8) and "OPEN" (AN9) showing 255.
Here is what we should usually expect to see as the roof transitions from closed to open, during NORMAL OPERATION.
When the roof is down, the CLOSED (AN9) sensor will show a signal between 106-108 indicating it can sense the ram is close by and the OPEN (AN8) sensor will show 255, meaning it cannot sense the ram near it. When raising the roof, the rams begin to move. Around the half way point (mid-way) both sensors can spot the rams at the same time as they glide through their action, eventually leaving behind the CLOSED (AN9) sensor, making it show 255 and the OPEN (AN8) sensor showing the 106-108 signal that the rams are now next to it.
This behaviour is what we are aiming for, by the end of this project.
Unfortunately, in this tech guide, because both sensors are reporting 255, the CCU cannot tell if the roof is open or closed and will refuse to activate the pump.
This is a problem.
Repair Options
The goal is to repair the Hall Sensors which, thankfully, is a fairly painless process, but the immediate problem is that the roof is CLOSED. Obviously, if your roof is stuck open, this will be easier for you (if you're not stuck somewhere on holiday), however we shall assume, for the purpose of this guide, the roof is stuck closed and you're in a place where you have some basic tools available and have purchased some Hall Sensors.
NOTE:: The sensors are universal and are used by many car manufacturers to detect the position of convertible roofs on all manner of sports cars etc. The best availability is via the BMW Part Number 54347190735
There are various approaches to getting the roof raised;
You will not need to disconnect any batteries from your T6 and you will not need to unplug anything in any particular order. The T6 systems are very resilient and have built in redundancy so feel comfortable and confident to just get on and do it.
TECHNICAL GUIDE
Symptom
Troubleshoot
- Press SELECT (push down on the control wheel) to bring up the normal menu
- Hold down the BACK (Bottom-right button) and SELECT at the same time, for 3 seconds.
- Choose "Diagnostics"
- Choose "Hardware List"
This is a problem.
Repair Options
- Releasing an emergency hydraulic screw behind the CCU and pushing the roof open by hand, from below
- Manually activating the hidden pump control module by applying a 12v feed to pin 23 on a plug behind the CCU
- Giving a raw 12v feed directly to the pump, bypassing the CCU entirely <---------
- Booking it in with a camper specialist who will raise the roof and change the Hall Sensors (Approx. £600 incl. labour and parts)
- Booking it in with VW who will raise the roof and change the entire wiring loom (Approx. £2200 incl. labour)
