Advice please Dash warning messages Ocean 2022
Thank you for the reply.
Will now have to cancel the MOT and rebook for sorting the lights.
So apologies for not updating….. mine went into the dealer…. No faults showing on diagnostic, sensors had a wipe over on front and all has been ok since fortunately so I don’t know whether one sensor triggered others!!
The safety systems depend on 4 functioning ABS sensors. If 1 has a hiccup then all those systems shutdown and Warning lights displayed.
I suspect the "wipe" over was not a physical cleaning , more of a Clearing of the fault codes from the ECU.
I did wonder, but as they’ve never reappeared must be a Cali gremlin…
Thank you for all your replies. They are very much appreciated.
The van is in for its MOT later this week, but first they will be sorting the fault lights.
I'll report back on their findings.
Thanks again. Great club!
Chris.
Just to add to the confusion I had similar warnings about acc unavailable etc and the van dropped out of cruise, pullover switch off/on and away we go for another 10 miles. Eventually got tracked to the oil level sensor in the dump, I kid you not. Still don’t understand why
Update on warning lights issue.
Turns out that one of the wheel sensors and the magnetic encoder ring are faulty.
This requires a replacement sensor and wheel hub with its integral encoder ring.
Despite 4 days of waiting, the VW ALL IN ONE cover finally approved the repair. Definitely worth the frustrating wait.
Just waiting for a call from VW to say your van is ready.
Finger crossed, no more amber lights until the next one!
Thanks for reading this thread.
GRRRR! Just had a call from VW saying they will not be able to complete the repair today as promised. Apparently, a tool they use for undertaking part of the work has broken, and a replacement is not available until tomorrow. More excuses and frustrating delays.
The tool probably didn't turn up for work !
Complete BS
Complete BS
Progress report:-
Informed tool arrived today...Yipee..when can I collect the van?...sorry sir, but the wrong bearing hub has been delivered. Correct one arrives tomorrow...Grrrrrrrr again.
I'll let you all know the VW company to avoid once I'm back on the road.
Just adding my recent experience with a failed wheel speed sensor on my 2020 6.1 Ocean...
3 weeks ago we stopped at a Forestry parkup near Oban, the night before catching a ferry for a 2 week trip to the Outer Hebrides. Switched on the ignition to open the roof and was presented with bings, bongs, and lights all over the dashboard. The pop-top did nothing when attempting to open it, however the motor did whirr when attempting to close instead.
Unfortunately we had no reception so put it down to an electrical gremlin and hunkered down to see if it cleared by itself in the morning. Whilst eating dinner all of the internal vehicle system lights and the headlights suddenly started to flash on/off every few seconds. We were in camping mode, vehicle locked, even turned the lights off but nothing stopped it.
Decided the strobe lights weren't really fair to our neighbouring vans so packed up and decided to head elsewhere to get some reception. About a mile down the road the indicator lights on the wing mirror came on solid for a couple of seconds and the system appeared to reset itself, so headed back up to the parkup.
Over the next couple of days the problem got increasingly less intermittent, until eventually the warning messages became permanent. By that time I'd found this thread explaining the likely cause so had no immediate concerns about driving the vehicle, other than taking a little extra care knowing none of the safety systems had my back. The flashing of the vehicle lights didn't happen again to the same extent either.
Van is currently in for a service and it's been confirmed the cause is indeed a failed wheel sensor. Just to help anyone searching for similar error messages to find this post though, here's a comprehensive list of what popped up on the dashboard each time the ignition went on:
  • Manoeuvre braking currently unavailable
  • Error: ACC
  • Error: start/stop system
  • Error: Hill Start Assist
  • Lane Assist currently unavailable.
  • Front Assist unavailable.
  • Side Assist and Rear Traffic Alert unavailable.
  • Error: Dynamic Road Sign Display
  • Error: Tyre Pressure Loss Indicator
  • Error: headlight range control
  • Error: Park Distance Control
In addition to none of these systems then working, we also experienced the following issues as they undoubtedly also need to know if, and how fast, the wheels are turning:
  • Electric roof doesn't open
  • Intermittent rain wiper mode does nothing
  • Reduced power assistance with the steering at low speeds
It would have been nice to have had the van in full working order for the trip, but you don't go to the Outer Hebrides if you're not looking for a bit of adventure, so we worked around the problems . The strong winds and driving rain meant we'd have had the roof closed almost every night anyhow!
Interestingly the service has also noted both rear coil springs are broken, which combined with a false alert about tyre pressures on the drive up to Oban makes me wonder if these might be related. I don't remember hitting any pot holes and the van was driving normally the whole trip so could be just a coincidence. Thankfully VW All-In is covering the cost of it all!
