Coffee-van
Hi!
I’ve got a 2005 t5 with the hydraulic elevating roof
I had a leak in both pistons and a cracked hose on left side on the car. Replaced both pistons and hoses on left side. 4 new position sensors from bmw were also fitted
Still the car think the roof is open. Hence I’m not able to open it from the panne ( i had to hoook the motor on to a battery to get the roof open)
Any ideas on how to get this sorted?
When i elevate the roof by batteri, the controlpanel works as intended intim i close the roof. Then it wont open again
Note: i might have mixed the two sensors front/rear on left side while replacing the piston. Is there any wiring scheme available? I suppose the wiring colour will tell front/rear.
Headliner is out at the moment, so i could theoretically measure the cable loom
