Perfectos
The length front to back can be adjusted to increase the available surface area. / storage based on your seat position
https://www.vanhackers.de/products/bauplan-des-schuhregal-fur-die-trittstufeDo you still have those plans please as the attachment links don’t seem to work?
Yeah I saw that and I’m probably just being blind but there’s no option to download them?https://www.vanhackers.de/products/bauplan-des-schuhregal-fur-die-trittstufe
here you can download the building plans
You are right, the download button disappeared when I went back today.Yeah I saw that and I’m probably just being blind but there’s no option to download them?
I made mine with thinner ply, supported with large dowel (broom stick ) cross brace to the top edge , then extended the length (longer than the suggested size) , fitted a usb / c charging panel (shows LB voltage when plugged in via a 12v plug switch ).Thanks Perfectos and Carabiner. Nice little project before my next trip!
