Warning! Are you going to Spain or Italy and do you have a bike carrier on the tow bar?
Allard Jongebloed
Allard Jongebloed
Netherlands
T6.1 Ocean 150
Warning! Are you going to Spain or Italy and do you have a bike carrier on the tow bar? Then keep the following in mind: you obviously need the white license plate. You are not allowed to place a country sticker on it (in my case NL)! But you *must* have a country sticker on the carrier! It is also mandatory to place two signs. Perhaps a bit excessive, but still... If you don't, the fine in Spain is 150 euros, and in the worst-case scenario, you won't be allowed to continue driving!
I attached the boards with zip ties. Use strong ones; I used 360 mm long ones. Pull them tight so the boards don't flap and you don't damage the bike. At your destination, just cut them loose. They cost about 15 cents each online.
I attached the carrier and the bike to the tow bar; there is a small opening under the ball that a long padlock fits through perfectly. Then I secured it with a chain and cables. That might seem a bit excessive, but what could happen? Crooks park a large van next to your Cali, cut everything loose with bolt cutters, and your (expensive) bike is gone!
One more little tip: place a tennis ball at the end of your handlebars. This can prevent your handlebars from going through your rear window, for example when braking abruptly.
Have a safe trip!
What's with the white plate requirement and is that a thing for us Brits too?
I know that but they are normally yellow when on the car, so wondered if that was a Dutch requirement or a Spanish/Italian one?
White ones are used in Holland for caravans, small trailers and bike carriers. Dutch requirements, not required by Spain, Italy or any ithe country.
According to my information, this is European regulation. But anyway, I don't know how that is regulated in the UK. In any case, this applies to every Dutch car. There are many Dutch users affiliated with the California Owners Club. Maybe I should only post this in Dutch next time... I'm just trying to help! So if you get pulled over in the Netherlands or Spain and get a ticket, I have warned you.
You are right, but you are not allowed to put an NL sticker on the white plate. However, in Spain you do need an NL sticker on the bike carrier.
To be precise, then, our country is called the Netherlands, not Holland. Holland is the name of the two coastal provinces, North Holland and South Holland.
I realize I may have caused some confusion with my post. Just for the UK, if you fit a bike carrier on the towbar, it must have a UK sticker on it. Image one, not ok, image two ok... With image one, you must have a separate sticker.
So why did we used to play HOLLAND at the World Cup?
Hahaha, you mean the UK versus Holland, or England versus the Netherlands (World Cup 1990)? Or maybe you are Scotsman, Welsh... Oh, I see, Birmingham...
I think we're straying a bit from our topic...
In some countries you can get a third license plate with the same number as your regular ones but with a different colour. If you don't have one then you just transfer your regular rear number plate to the carrier.
The colour of the third plate is different so it can't be used on a car. The ones in Italy are yellow and my Swiss one is red.
I was in Italy for a bicycle meet 2 years ago with a large group of Italians. They asked me if the sign on the carrier was a Swiss requirement and were surprised when I told them that it was actually an Italian requirement. I'm guessing its not really enforced in Italy.
Image 2 is not ok as that’s the old GB sticker it now needs to be UK
For Spain the sticker on the end of the number plate isn’t enough, it needs to be a seperate white oval
  • Agree
Reactions: Sad
And in Portugal you can’t have bikes on a rear bike rack, or have I misread that?
No offence, but that is a bullshit post.
I've lived in Italy and Spain past 5 years. I always travel with my bike. I carry the red/white board in the trunk, but I've never had to do it. Nobody cares. Same with some country stickers - nobody cares.
Similar with three plates. I got the third one now recently, but all previous years, I always had just two. Again, never any problems.
Locking bikes is a good idea. But I lock it directly to the towbar under the towball. Not to the carrier, which can be removed together with the bike. (probably fine with cheap bike, but not sufficient, once the cost of the bikes is half the price of the van)
Pretty sure Halfords is out of date with their information. I can't find the exact bit of legislation, but I recall it changed around 2023 and they are now legal.
Decent video explaining it all:
Good to know. It did seem strange, thanks for clearing that up.
