Trying to get to grips with T7 PHEV Aux Heater
MikeCW
Shrewsbury
T7 California Ocean 4 Motion
We’ve just done our first night away in our new PHEV T7 California Ocean. It was -1’C outside…Plugged into mains, full tank of fuel, we set the auxiliary heater to continuous operation. However after 3-4 hours of operation we were tired of the constant rhythmic knocking noise, very light but noticeable and enough to keep us awake. I turn the heater off until I woke 6 hours later, by which point the van was freezing. When I tried to turn the heating on, I immediately got an error saying emissions limit reached and van needed to e driven above 5km/h - no practical at 5 am..
I know that heat immediately gives this message and it may be that I selected heat immediately in my sleep haze and it counted the 4+ hours of continuous operation the previous night, but either way, we were freezing and the heating wouldn’t work in either continuous or heat immediately mode until we had driven then vehicle.
Has anyone else come across this “feature” - my dealer tried to tell me that the heater in either mode is only designed run for a maximum of 3 hours, including the technician, but I have gently suggested he goes back and checks this with VW as I know from other forums that you have to use continuous mode overnight…Is the knocking normal? Has anybody else had the emissions error after using continuous mode?
Knocking is normal - that's the pump getting the fuel out of the tank to the heater - I strongly recommend "loop" earplugs - expensive but very good! Otherwise on my diesel T7 as long as I use "heat continuous" it's been fine - had it switched on when parked up at site, switched it off when we went out for the day, then back on again in the evening all night. I wonder if you accidently used heat immediately
Thanks - if i did use heat immediately it was first thing in the morning and it may have counted the 4+hrs of continuous as having been running under het immediately and tripped the emission lockdown.
It seems odd that they have the 3 hours lockout if it will safely run overnight anyway.
Air Pods Pro 3s are now on my packing list…
No-one is quite sure why they have 2 options, I assumed that it was because the heat immediately was a different heater or something but given it all comes out of the same place it's a mystery
This may help
Same with the knocking sound. I got used to it but it's a shame it's not a little quieter.
And the "feature" that forces you to drive your car in the middle of the night is hilarious. But when I use the continuous mode, it works fine.
That’s because heat immediately is really supposed to be for the water heater (parking heater) which is run off the engine battery hence the requirement to drive it in case you can’t start the engine. Read the linked thread above for an explanation.
We have done one weekend away in our PHEV too in similar temps. We used continuous heating which worked fine. We also switched off overnight though, partly due to the steam engine type chuffing coming from the heating pump in the background, and partly as we thought it might be too warm if we left it on. We actually slept very well but I did switch the heating back on at around 6am as the van was indeed freezing. We didn’t experience any time limit issues but I was careful to use continuous heating rather than immediate heating.
The thermostat does work well to stop it cooking you overnight - we run it on 5 and it's cosy without being overwhelming
I have similar (?) problem with my T7 (Diesel, not PHEV). At least two times already at night my heating (continuous one) turned off by itself, w/o any errors or anything it seems.
I wake up freezing, and since I sleep on the 2nd floor, I just use my phone to kick in "Heat Immediately" (why the f*ck I can't turn on the continuous mode from the phone?!) and in the morning I get this fancy "Emission limit reached" crap. Oh yeah, I need to fold my awning, move camping stuff around to please VW and move my car back and forth 30m to get heating back.
Hilarious.
Hilarious.
Completely agree - there a software/OS update needed to allow you to Heat Immediately from your phone, and possible to get rid of the 4 hour heat immediately faux-pas!
I’ve used the heater a few nights now and works well but also agree the two features are overly complicated, maybe something SW might change in the future.
I do find the knocking noise annoying, and surprised it’s not better insulated or perhaps a better OEM product. I had an Eberspacher heater fitted to my previous T6 and was almost silent after the initial start-up. Has anyone ever considered dampening the pump or alternatives updates? Do you know what product is used by VW?
In my T7 the fuel pump I can't hear almost, even when sleeping below with my head backwards. I do hear it, but only when I focus.
Maybe in your case there's some fault with it...
You could always crawl underneath and see how the pump is mounted? It will be in some sort of AV mount/cradle. Maybe it just needs tweaking or a better /softer mount making up?
Nice little Easter project for you.
Thanks all, just had another couple of nights away and it’s too intrusive to sleep. By way of a comparison - the fridge has a “quiet mode” and we can’t hear the difference due to the noise of the heater
It’s going back to VW on 22 April for them to see what they can do
Hi..I have the T7 Ocean phev...auxiliary Heat exit is under the kitchen (see pic circled in Green) when switching from California app. But when switching with My VW app exits either from the right side corner at the sliding dolor(see pic) or from the front exits and have no clue why. Any help? Thks!
You cannot switch the camping heater from VW app, only the engine heater (Webasto).
Camping one heats air directly and Webasto heats the engine coolant.
In other words , when you start the engine heater from My VW app does it work with petrol?
Confused by this thread but pleased to have found it.
So there are two heaters? At 6am over the weekend it was pretty cold so I used the California app to turn on the heating which worked fine, but it was only on for 20 minutes and I did not have any emissions warning.
There's also a button on the dashboard - does that turn on the same thing?
Both heaters work from petrol/diesel. The difference is that Webasto heats the engine itself through coolant, which in turn heats air. And that is why air is coming from the usual ducts.
Second one heats air directly and that air is blown from under a fridge and I think also from the duct in the trunk on the right.
Thank you!!! duct/air coming from the trunk is another confusing issue; I have to double check but it is not coming from camping heater for sure; it might come just from webasto
Hi, Another question....Ocean T7 hybrid... fridge at level 4 ( scale of 5 ) stationary battery decreases from 100% to 20% in 24 hours when not plugged in and the van stopped. Making some numbers (probably in a wrong way) I see that consumption of fridge is between 0.15 and 5 mA/hour (seen in panel) depending on wether the fridge compressor is on or off; assuming that there are very long periods being off and I take for granted an average of 3 mA /hour the batttery should last around 48hours ( 2* 75mA/h lithium batteries); can anybody tell me his/her experience? Thks in advance
Fridge is 50W. Ohms law gives approx 4A.
Fridge duty cycle is normally around 20mins so 1hr in two
Different fridge on the T7 so Transporter fridge power consumption may not relate.
The % calculation is a spot calculation and can be very inaccurate. What voltage are you seeing? The voltage is accurate.
